Serpentine Belt Conversion for 1984 S10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2008, 08:12 AM
Having a problem trying to covert a 1984 S10 2.8 liter engine in my truck to a Serpentine belt system using all hardware (ps,alt,smog pump,& a/c) including brackets from a 1987 Blazer(84 is V belt driven CW, 87 is CCW serpentine driven) . The water pump is not interchangeable but found out that the 60 deg.V6 was used in other makes of cars and trucks. Anybody have any information or suggestions on this conversion. The 87 water pump base is different and the housing is shorter, I tried a water pump out of a Fiero, the base is the same but the housing is also to short.
Old 10-26-2008, 05:06 PM
SSedan64's Avatar
My sons 85 4WD Isuzu Trooper came with the GM 2.8 with the CCW serpentine setup. May give that part# a try.
Serpentine belt slips 96 F250 Furytom Engine 8 11-26-2008 09:02 AM
serpentine belt water pump direction? trucks_chevrolet Engine 16 04-15-2008 10:49 AM
serpentine belt smell 67tiger Engine 11 06-16-2007 12:06 AM
Serpentine belt conversion, older 350 murrsue Engine 6 01-12-2005 07:25 AM
87 s10 v8 conversion too__old_for_this Engine 5 11-23-2002 05:24 PM
