Serpentine belt miss match question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2013, 04:09 PM
iceman36's Avatar
If the engine crank pulley has a 4 slot AC compressor pulley, and the AC pump has a 6 slot pulley assuming proper alignment between the two pulleys.
Would there be any problems using a 4 slot belt being the old AC was a 4 slot AC and worked fine?
This is being done by installing an AC pump with a different attachment design and a new bracket to move the AC in and down for frame clearance plus a shorter belt.
Only other options would be to find an OEM crank pulley with a second 6 slots, or see if the AC could be changed over to a 4 slot pulley.
Does anyone know if there is an OEM crank pulley with a second 6 slot for AC that would fit without moving the front belt passion?
Engine: Pontiac 2008 LS G8 L76 6.0L.
Ice
Old 01-03-2013, 05:14 PM
If the old A/C worked with 4 groves and the diameter is the same I don't see why not. Is the belt or set up your talking about only powering the compressor?
serpentine belt coldfreshwater Suspension - Brakes - Steering 0 01-01-2013 08:32 PM
LS Serpentine Belt Help iceman36 Engine 0 12-29-2012 05:18 PM
serpentine belt & water pump belt coldfreshwater Engine 3 12-19-2012 07:03 AM
v-belt to serpentine Titanium Engine 12 11-07-2010 07:28 AM
going retro from serpentine belt system back to v-belt can i swap out the reverse ro motorhead1945 Engine 5 06-25-2007 07:56 PM
