below is how my TBI 5.7 V8 in my 87 suburban is, but I bought a 3 month old GM crate engine that was in a 90 chevy p/u that lost the drie shaft and broke a new 700R4 tranny around the bellhousing (
daddy told his boy after a engine swap & 700R4 tranny swap to sell it, and he would buy the boy a new ex cab 4x4 p/u). I bought the complete 5.7 TBI engine with everything, a 1 belt serpentine belt system, water pump, fan, TBI, PS pump, A/C pump, just everything for $800. I'm going to put this 1 belt serpentine belt system on my 400SBC with a/c in my 74 Camaro. its a reverse rotation standard flow water pump with this 1 belt serpentine belt system.
did I say that right ?
some info I found
[/i]ON OLDER MOTORS YOU HAVE TO TAP AND PLUG A SMALL HOLE ON THE PASSANGER SIDE OF THE WATER PUMP PORT THE NEWER WATER PUMP DOES NOT USE OR COVER THAT HOLE you can see in the picture what the style of the front of a motor this came off [/i]
thanks
Originally Posted by fiscus
This thread seems to be going in a lot of different directions at once. I want to comment on the SBC water pump topic, there does exist a standard rotation water pump setup with a serpentine type belt. I have seen it in person on a canadian '86 cutlass with a 305 engine. It had a serpentine belt going around the crank, water pump and alternator, and a v-belt for power steering. There was no tensioner, and it used the old-style alternator bracket to get the belt tight, and the regular water pump.
Here's some pictures of a pair of pulleys I have lying around that I think are the ones I'm talking about.
