Serpentine conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2012, 09:13 AM
billonwheels's Avatar
Last journal entry: On the Road
Man I'm thinking about doing a Serpentine conversion on my Pontiac Grand Prix. Any down sides to doing this? and what type of Electric fan do you all recommend?
Old 03-18-2012, 09:18 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Nothing wrong with a serpitine set-up but i would stay with a good mechanical fan with a fan shroud if i was you . JMO
Cole
Old 12-13-2012, 08:17 PM
I went with the billet pullies with an electric fan. So far so good. Looks really good.
Old 12-13-2012, 08:34 PM
techinspector1's Avatar
Wiki Edits: 326
I would have rather spent the money on hair plugs.
The Following User Says Thank You to techinspector1 For This Useful Post:
billonwheels (12-13-2012)
Old 12-13-2012, 08:46 PM
lol! Thanks I needed that Laugh tonight!
Old 12-14-2012, 12:26 AM
There are no reverse rotation water pumps for Pontiac motors. The only available "serpentine" kits use a boatload of idler pulleys to put sufficient tension on the belt. Basically you're paying a TON of money for a pseudo-serpentine belt drive that has MORE friction (and thus HP loss) than the stock V-belts.
Your money, your choice.
Old 12-14-2012, 11:04 AM
X2 on the hair plugs! This is a lot of cost for no techical gain, just eye candy.
Bogie
Old 12-14-2012, 11:16 AM
I have never heard anyone say serpentine belts are less efficient, in fact, just the opposite although the difference either way is probably negligible. If you want the longer life and dependability of a serpentine belt, you can buy the pulleys for each drive/driven part and have it work and rotate the same as the V system did. You'll probably never get your money back from the longer life of the serpentine because you usually have to buy high dollar ones from March or other manufacturer, but money is almost never the reason we modify our cars.
Old 12-15-2012, 10:17 AM
Go back and re-read my post. TRUE serpentine belt drives, like the factory installs, do, in fact, have less drag and use less HP. The factory serpentine drives typically use a reverse rotation water pump and LOTS of belt engagement on the pulleys to get the same drive force with less tension in the belt.
Aftermarket conversions for engines like the Pontiac that don't have reverse rotation pumps available rely instead on three or four idler pulleys to force the belt against the water pump pulley (and the other accessory pulleys). The sole purpose of these idlers is to increase the force on the belt, making up for the fact that there is only a limited amount of engagement available between the belt and the water pump pulley. This extra force must be reacted somehow, and that reaction takes the form of added friction and thus more HP required to turn the accessory drive. Is it a large number? No, of course not, but the whole point is that you are spending somewhere well north of $1,000 for a pseudo-serpentine drive that provides exactly NO performance improvement but increases complexity (due to the additional idlers).
Again, factory-style serpentine is fine. Aftermarket "pseudo-serpentine" is a waste of money.
serpentine oakstao48 Hotrodding Basics 1 08-19-2010 08:36 PM
BBC Serpentine Conversion 80PontiacWagon Engine 4 02-27-2010 03:07 AM
Serpentine Belt Conversion for 1984 S10 WR Mouton Engine 1 10-26-2008 06:06 PM
March serpentine conversion kit SSon18s Engine 3 12-18-2006 09:37 PM
Serpentine belt conversion, older 350 murrsue Engine 6 01-12-2005 08:25 AM
