Serpentine setup in a `57 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2009, 04:09 PM
47 Coupe's Avatar
I'm putting a serpentine setup from a early 90's pickup in my 57. It looks like the radiator will have to mount on the front side of the core support. Does anyone have any picture of this setup with the mechanical fan?
Old 06-27-2009, 04:49 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Check out my photo gallery there is one in there, it should be the first one. It might help. this is with the electric fans one in front not needed and one on the engine side needed. Cole
Old 06-27-2009, 07:17 PM
If I remember correctly, the radiator was in front of the radiator support for 6 cylinder cars, and behind the radiator support for V-8's.
Virtually all small block serpantine drive setups use the long water pump, but the original V-8's used short water pumps.
I think there's only about an inch difference between the two.
I don't think you'll have any problems mounting the radiator in front....
JA
Old 06-27-2009, 07:24 PM
47 Coupe's Avatar
Do you know if I can just turn the V8 horsecollar 180degrees or is the 6 cylinder one different?
Old 06-27-2009, 07:44 PM
I don't know about horse collars. Is that a sheet metal spacer between the radiator support and the radiator? (I have one of those on my '64 El Camino)
If so, maybe you could just leave it out and mount the radiator directly to the radiator support and get the room you need.?
Old 06-27-2009, 07:50 PM
47 Coupe's Avatar
The u-shaped radiator support is what I was calling a horsecollar. Are the V8 and 6cylinder the same, just rotated around?
Has anyone ever converted a 68 302 v-belt to a serpentine setup. mike65 Engine 14 01-04-2012 08:42 AM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
85 and older 350 serpentine belt setup help jeff_5_7 Engine 4 09-11-2008 10:12 PM
serpentine setup on old style chevy 350 84cutlass Engine 6 03-16-2006 08:51 AM
What would be required to change a 400 SBC to serpentine belt setup stonedchihuahua Engine 7 02-10-2003 06:02 AM
