Serpentine swap to sbc
Not much on this topic (that I've found) but, what would be a good doner car?I've read somewhere else that someone used an 88-92 F-body set up w/alt.and ps.pump. Wanted to know if anybody else took this route.Also (I guess) that in this swap , you have to get a reverse water pump?What about the flex fan? , can you just turn it around? I am hoping I can do this on a "junkyard" budget cause the March pulley set up is a little pricey.
Thanks ,Ant |
Thanks DV. Its going in an 84 cutlass w/400 sbc.No Smog pump, just P.S. and Alt.- Did not know about the flex fan robbing h.p.-it is a little annoying. I believe the p.s. lines are metric ,since most of this car is.As far as the clutch fan , what type of chevy truck (year)or is it any w/serp. set up ,like you said.?The same fan from the camaro is no good? Why get a set of different blades off doner car? My guess is ,they are to tall?Sorry for all the questions but I am really into this swap cause I allready threw the alt.belt once under heavy rpms , and everything is perfectly lined up w/proper belt sizes and tight. It tends to "bounce" when you goose it.
THX. Ant. |
Since you don`t plan to run A/C, the belt will have to be shorter. In your case I wouldn`t go with the serpentine, I would get the Dayco heavy duty alternator belt, I used to have the part number but I don`t anymore. They cost around $22 a pop and they are alot thicker than the stocker, I used them many times and to 7000 RPM and never threw it off. If you used a serpentine belt system it wouldn`t look right, since half the engine would have the brackets and the other wouldn`t, since one side supports the A/C compressor. by going with the heavy duty belt, you`ll save cash since you won`t have to buy the serpentine system and do all the work, you won`t have to swap water pumps or worry about reverse rotation fans. I would still get a clutch fan, but make sure you get one thats a heavy duty thermal unit. Also make sure you have the proper shroud, the cutlass V8 Shroud works nicely. I have a 86 cutlass with a 350 chevy, it`s the same system I used. My car will soon be parked and robbed of parts, as the rust monster has gotten it, the time it spent in the north by the previous owner wasn`t good for it.
Once again ,thx DV.
Probably best to get a new one.Sorry to here about your 86. The junkyard by me gets about 2 a month and they ain't worth diddly
But I would have to agree with DV if do not run AC. My 94' Suburban came without a smog pump, but AC, PS, and Alt. Look at the following belt routing diagram. The diagram is wrong, it should read "With A/C" at the dashed line. Without AC, I cannot picture how you could make any factory serpentine belt system work, unless you installed a AC delete pulley, which are available. Ed www.edgesz28.com |
Yes , unfort. I don't have a/c so I'm bummin' . Maybe some new V-pulleys then w/Thick a*s belts. Underdrive anyone?
Thank you for all replies.
I robbed some pulleys off an '86 GMC van. It's not a true serpentine setup but the water pump, alternator and crank pulleys were all I needed. The p.s. pump belt never jumped ship on me. It was just a pulley swap on my 400. The alt. bracket is from Alan Grove components.
Here's a couple of pictures. Larry |
i gotta serpentine set off of a 93 c1500 an it had a/c, do any of u know how to remove it an still make beltz follow order? i've already removed the air pump, so now im jus runnin an alt., p/s, fan, crank, an r-12..........
Basicly , thats what I want to do. A simple conversion like yours coldknock. But how is the ps pump running? still on a V? if so ,did you just sandwich the crank pulley with the serp.and 1 single groove?
p.s. nice alt. brackets |
Below is a picture of the entire GM kit #NAL-12497697 available from Summit. The AC delete pulley is pictured between the belt and water pump. ![]() If you do not want AC but retain PS and Alt, your best bet is to set up a system like Coldknock did. One more thing, if you go to a junk yard to get a TBI serpentine system, be sure you bring a PS pump pulley puller. You CANNOT get the bracket off the engine without first removing the pulley and PS pump, see the bolts hidden behind the pulley below: Ed |
Larry |
I'll be on the lookout for an 86 GMC van.
Very cool info,Thank you.
I got the exact same set-up on my truck and got all 3 pulleys from a 1986 Chevy truck. Never had a problem throwing the power steering belt but would throw the alternator belt regularly. Now the the alternator being on a serpentine and the power steering being a v-belt, the alternator belt stays on and still keeps the alternator charging at lower rpm's for my electric fan setup. The total cost was right at $40 ($20 for pulleys and $20 for belt).
| SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine | Oldsmolac911 | Hotrodders' Lounge | 50 | 01-12-2011 10:00 PM |
| SBC Serpentine System | MI2600 | Engine | 9 | 06-22-2005 03:13 PM |
| 4.3 to SBC swap in an S-15 | adryan16 | Engine | 1 | 12-30-2003 07:52 AM |
| What would be required to change a 400 SBC to serpentine belt setup | stonedchihuahua | Engine | 7 | 02-10-2003 05:02 AM |
