Service Engine soon light
Hey guys and gals. I just changed my spark plugs today. I used E3 brand spark plugs. I have a 2003 Chevy blazer. The Blazer runs great, but now the service engine soon light is on. Anyone know why or how I could fix this problem?
You will have to have your codes scanned to see what has turned the light on . It can be one of many things. Oh yeh...If you filled up with gas recently...check to be sure your cap is on properly... if its not...this can turn the light on also.
Hi, I work with E3 and happened to come across this bulletin and thought I would throw in my two cents...E3 improves combustion and sometimes the computer takes some time to figure out what has changed. Unless you are having noticeable problems with the car, I would suggest driving through a tank of gas and see if the light goes away. Also as "Henry Highrise" said, the gas cap being loose is often the cause for the light...Good Luck.
The E3 plugs will fire with a diffrent resistance value than a normal plug, computers might not like that and therefor throw a code for the ignition system. I do not belive that ANY spark plug create so much better combustion that it causes off readings with the 02 sensors, that is the only way the computer can sense better combustion, and it's a long shot at best..
check the codes, if it's anything ignition related, the plugs are to fault |
I'm not failure with "E3" brand plugs but I'd say they are the crap that walmart sells off the shelf. An 03 Blazer calls for a DOUBLE platinum plug, and without them your probly throwing the random multiple missfire code (PO300) Or a cyl mis fire (PO301-306) |
All I know about E3 plugs is that they have 3 electrodes..
cel
just something to think about during the process of changing the plugs you may have unplugged something that didnt get plugged back up. just make a quick check of all the engine harness connectors and make sure everything is tight.although the best way to find out what it is is to have it scanned then you will know exactly what is wrong, good luck.
I agree, there is no advantage to multiple electrodes
so far joe, you're the only one that has a grasp of late model stuff... btw, i HAVE run into a couple of cars that will dump the codes by disconnecting the batt BUT they ain't domestic... camarolover could be right also, but my guess is that you cracked a plug or got a bad one (it happens) my suggestion would be get it scanned and go from there...
THAT'S THE BIGGEST BUNCH OF BS I'VE HEARD IN A LONG TIME!!!! the 'puter does NOT have to "relearn"a different set of plugs! a tank of black gold ain't gonna change anything. i hope you are not an engineer for e3 (btw, never heard of 'em but it sounds like the old splitfire crap to me) want someting to run like crap? bosch platinums or splitfires will do it for ya... all that being said, if you filled up with the engine running or left the cap loose, it'll turn on the light BUT so will a 100 other things. get the codes pulled before you do anything else... |
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| check engine (light) | JMEDLEY001 | Engine | 8 | 02-03-2007 04:01 PM |
| oil warning light | romaro | Engine | 3 | 09-15-2006 09:31 PM |
| strange engine problem with check engine light | brian12c | Engine | 2 | 07-29-2006 09:55 PM |
| Service Engine Soon | phil1949 | Engine | 6 | 08-31-2003 08:31 PM |
