service engine soon light - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2006, 12:38 AM
my service engine soon light comes on like two minutes into the ride and when i shut off the engine and turn it back on it, it turns back on again in like a minute or two what can be the problom?
Old 06-13-2006, 12:42 AM
Could be any number of things. You should have some one plug in and check for any failure codes.
Kim
Old 06-13-2006, 12:52 AM
88Chevy,
I am guessing that this light is in a 1988 Chevy truck? Or is it a newer vehicle? Doe it run alright or does it idle really fast? Does it have a mis-fire? Does the light stay on once it comes on? How many miles are on this vehicle?
Scholman
Old 06-13-2006, 12:57 AM
engine light
yeah its on a 1988 chevy truck TBI 350 the heads are rebuilt but the odometer say 163000 miles and once the light comes on it stays on until i turn off the truck and the truck doesnt hesataite or anything like that
Old 06-15-2006, 12:38 PM
my '95 Z71 has that problem, some sensor in there.....never bothered to change it, doesn't bother me...
Old 06-15-2006, 12:50 PM
Siggy_Freud's Avatar
Go to autozone, and ask for a GM code key. They should give you on free. If not, you can use a paperclip. Put the key, or two points of the paper clip into the two most upper right spots on the diagnostic plugin (should be spots A and B). The engine light will begin to blink. It will blink once, then twice and repeat that three times. It will then blink out the two digit code three times, followed by possibly another code. Once all the codes are done, it will blink once, then twice (which is code 12) to let you know its done reading off the codes.
The engine light is coming on for a reason. The comupter will tell you that reason, you just need to check it.
Bringing history and technology together.
Old 06-15-2006, 09:45 PM
i got the codes and got three but i have a 1992 caprice cop engine in the truck and i also have the cars computer hooked up to the truck and i pulled the codes out and code 23, 24, and 44. Should i hook up the trucks computer also and check that one too?
Old 06-16-2006, 04:06 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Are you saying that you are running a 92 engine off an 88 computer..Or did I not understand correctly?
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 06-16-2006, 07:51 AM
02 sensor maybe
Old 06-16-2006, 08:26 AM
MI2600's Avatar
Member# 3287
I agree with a probable O2 sensor. The engine runs on a closed loop until it warms, then switches to open loop...a couple minutes.
Old 06-16-2006, 10:23 AM
NorthStar's Avatar
Some of the codes you got dont seem right.
23 - ?? not sure what this is ??
24 - transmission input shaft greater than 3000 output less than 200
44 - lean O2 sensor reading
Check for exhaust leaks at manifolds and down pipes.
Replace O2 sensor.
Fuel pressure.
Do you have the right throttle body for your engine and computer?
Old 06-16-2006, 04:46 PM
im running the 1992 engine with the its own computer
CA smog questions...engine swaps curtis73 Engine 25 11-28-2012 09:11 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
Verifying engine pedigree... johnnya Engine 3 08-04-2004 07:42 PM
Service Engine Soon phil1949 Engine 6 08-31-2003 09:31 PM
Golens Engine Service ztoy Engine 2 05-29-2003 07:42 PM
