Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Servo Motor MOD: DIY Easier Speed Control
  #28 (permalink)
Old 12-23-2012, 05:55 PM
John long John long is offline
Originally Posted by beachbum jim View Post
I just received the Sew Quiet SQ5000. Looks like they already made the modification. I was ready to do it my self but after depressing the lever on the bench, it slowly sped up and got faster as you pressed down on it. The thing works GREAT!
Jim, I think you will love the SQ5000. Even if it turns out you need to make the modification. You will know after you install the motor and run it under load. It is very easy to do. Good luck.
