Arrgh...it's past 10PM and I just got home from work but now I want to crack open my SQ5000 and attempt this mod.
From the beginning I have had a thick piece of white sheet styrene in mind for use as the diffuser; I've got a bunch of it left over from another project. I still can't believe that this went largely unnoticed on the very original forum it was posted on! Ok...I'll be back in an hour or two (runs off to get his camera and styrene). |
...(runs back to the computer) That was fast! I actually finished a half an hour ago, so it takes about a half an hour to do this mod if you take 3 tries to get it right.
I found the thick piece of styrene (about 1/32") to be too thick, but I had a piece of thin styrene...maybe .010" or so that I spray painted a black stripe on. I also shaped the styrene so that it would gradually and increasingly block the light source as the pedal was pressed. The results were unbelieveable! This was what I was expecting when I bought the SQ5000! A nice, gradual build up in speed from 1 to the programmed speed over the full range of the actuating lever. In the end, the thickness or translucense of the diffuser I made probably didn't matter a whole lot--I found that the diffuser I made was mostly the same shade of gray and that the gentile speed control was due primarily to the way I cut the diffuser so that it would more gradually (than the original) block the light the further it was rotated into the light sensor. I know that this was the principle of operation of the original factory diffuser, but they got the shape wrong...That arc cut into the diffuser is much too sharp--it needs to be a long, gradual arc. I think you could probably cut the original diffuser so that it blocked light transmission more gradually, but I didn't want to test this out by making any permanent changes to anything because my servo motor is still under warranty. Thanks again to Larry for cluing us in on this! Spray Painted Styrene: ![]() New Diffueser Stuck To Old Diffuser Using Ultra-Sticky Seamstick Canvas Basting Tape: ![]() ![]()
| The Following User Says Thank You to SafeAirOne For This Useful Post: | ||
Cronko (08-01-2012) | ||
SafeAirOne,
Nice to see that it worked out so good for you with the plastic. Altering the shape of the plastic strip instead of the translucency makes it even easier ![]() Looking at the pictures of your control-arm, I see that the factory have tried to change it a little from the earlier model. On my SewQuiet 4000 the arm is just a square piece of steel, while your SewQuiet 5000 at least have a radius on it. Now itīs time to run and find some plastic....
Excellent news, now we know the popular SewQuiet 5000 works and the list grows by one. SewQuiet 5000 SewQuiet 4000 Skyrit TN-411 (looks very similar to a Consew) Enduro Pro SM600-1 I just did a production run of a project last night and I am in kats *** heaven with my machine. Until last night I had only tested the mod on scraps but last night was a true test and man what a difference, the smooth control was absolutely incredible. This project is a mix of go slow and accurate to long straights and prior to this I would just leave the speed at 3 and limp along on the straight stretches. Not anymore, now I can slowly build up speed to a controllable high speed for the straights and come to a crawl for the tight spots. Productiviy increase here I come. I'm off to catch some Z'zz have a great day all. |
| The Following User Says Thank You to SWFLholsters For This Useful Post: | ||
Update:
When I tested it after buttoning it up last night, I was hitting a max of "11" with the machine set to 15 so today I popped it open and adjusted the shape and position of my...I was calling it a diffuser, but it's more of a light blocker...so that I could hit "15" at full travel..
Here's the size, shape and position of the light blocker that did it for me--It starts after a half centimeter of lever travel, will hold a speed of "1" all day long and will hit "15" at the end of travel with a steady, predictable graduation in speed. NOTE that the arm is rotated away from the sensor just to take this pic--I positioned it correctly after the photo: THE FACTORY SHOULD BE MAKING THE LIGHT BLOCKERS IN THIS SHAPE:
| The Following 3 Users Say Thank You to SafeAirOne For This Useful Post: | ||
FWIW, last week I sent The Reliable Corporation an e-mail extolling the virtues of this better way to control the speed on their SewQuiet line of servo motors. In fact, it was mostly an e-mail of me going gaga over it and a link to this thread (and therefore Larry's site and the original "discovery" by DDHAL).
Susan, their Customer Service Rep, forwarded it on to their Service Manager, Nathan. Even though they don't produce the motors or the parts, it'd be nice to see them have some 'correct' speed control arms made up and offered to users. |
SWFLholsters (08-06-2012) | ||
Just got back from the NSRA Street Rod Nationals. Could not wait to play with this. I used an old worn out "bondo spreader" which was a little too transparent. I added 3 layers of masking tape and shaded it with a pencil and then one last layer of masking tape. I had not seen the last few posts or I might have gone with SafeAirOnes's method but this truly worked great also.
Here are some pictures of what I did with excellent results. ![]() ![]()
| The Following User Says Thank You to John long For This Useful Post: | ||
SWFLholsters (08-07-2012) | ||
It seems like I might give this a try using plastic from a gallon milk jug, sharpie marker, and a hot glue gun.
Plan B might be to use layers of duct tape to make a "flag" for the arm. I'm having the problem where every so often, even though it is set at "3", my SQ5000 will surge to full speed for a split second on starting. Not every time, but enough to **** me off. ![]()
Glad I found this thread!
I'm expecting a new Cobra Class 4 in about 2-3 weeks so I can't wait to try this out.
My current Highlead/servo motor combo works fine for me and it isn't one of the digital speed controllers anyway. Like someone said earlier, I've learned way more on here than I was learning hanging out at the upholstery shop tearing down furniture! ![]() Bobby Home Page |
John L |
I just received the Sew Quiet SQ5000. Looks like they already made the modification. I was ready to do it my self but after depressing the lever on the bench, it slowly sped up and got faster as you pressed down on it. The thing works GREAT!
John L |
| Tags |
| motor, servo, sewing |
| Recent Interior posts with photos |
| servo motor suggestions | danios | Interior | 14 | 01-12-2012 12:38 PM |
| Servo motor versus Clutch motor questions? | jcarter | Interior | 9 | 01-12-2009 09:19 AM |
| servo motor or speed reducer pully? | 60ch | Interior | 5 | 12-20-2008 04:16 PM |
| Transgo Mod - Rear Servo Washer Stack | 68NovaSS | Transmission - Rearend | 4 | 09-03-2006 06:17 PM |
