set pinion out of car - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2008, 04:23 PM
I know I need to set my pinion between 2/4* can I set it out of the car?
Old 02-06-2008, 12:34 AM
Jr 1948
Last journal entry: frame painted and motor is in
hey you got to get your rearend all lined up underneath to your pinion then tack weld your perches for the leaf springs on then pull the rearend out and do a full weld on them but be careful with welding them you don't want to warp the metal hope that helps
Old 02-06-2008, 10:57 PM
Wiki Edits: 49
You can not set the pinion angle outside the car. The pinion angle must be set with the rear end mounted and weight on the wheels.
Old 02-07-2008, 08:18 AM
ok
you both are right. I set it out and then put it in and it was off at lest 4*. glad I did not weld yet.
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 02:32 AM
how do you think I should set up a 2400lb kit car Mikemg Engine 0 12-06-2007 08:41 PM
Building a rack & pinion set up 60tbirdrick Suspension - Brakes - Steering 9 08-31-2006 11:10 PM
First paint scheme for '59 Caddy by me Nightrider Body - Exterior 54 07-05-2005 03:27 PM
"Basics of Basics" Photographing your car. MARTINSR Hotrodders' Lounge 3 06-01-2005 06:25 PM
