set timing without a degree wheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2006, 07:43 PM
I have no degree wheel and I need to set the timing on a 400 sm block Chevy motor with a .512 lift camshaft, can anyone tell me?
Old 11-13-2006, 11:06 PM
327NUT's Avatar
Obviously you're talking about degreeing in the cam ?? not ignition timing ? If its degreeing in the cam I feel it safe to say that most guys that build their own engines ( in thier garage ) dont use degree wheels. Its a good idea but just not always done. If you dont have one then just follow your timing chain/gears instructions, most set them straight up.
What should my timing be set at? chevyelc81 Engine 1 08-06-2004 04:11 PM
Using Wheel Scales To Set Preload BillyShope Suspension - Brakes - Steering 8 04-20-2004 06:35 AM
Timing Marks ??? Zeder Engine 6 10-08-2003 07:10 AM
Degree wheel setting my cam timing 70 nova Engine 8 04-13-2003 01:08 PM
BBC Timing Top Rod Engine 0 06-09-2002 08:29 AM
