set timing without a degree wheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2006, 07:49 PM
I have no degree wheel and I need to set the timing on a 400 sm block Chevy motor with a .512 lift camshaft, can anyone tell me?
Old 11-13-2006, 08:42 PM
Bare Knuckles Champ
Last journal entry: Made a wrench...
Timing?
Are you setting the ignition timing, or are you setting the cam timing (which is the only reason I can see for a degree wheel)?
Old 11-13-2006, 10:58 PM
There is no way to degree a cam without a degree wheel, unless you simply locate TDC on #1 and line up the dots.
Old 11-14-2006, 11:34 AM
DaSouthWon's Avatar
I put up the tools against$300
Is this like an emergency type deal or you don't want to buy a degree wheel?
Old 11-14-2006, 01:26 PM
johnsongrass1's Avatar
Race it, Don't rice it!
You can make a degree wheel with cardboard a protractor.
Old 11-14-2006, 06:58 PM
DaSouthWon's Avatar
I was headed that way but didn't wantto admit that I have actually used a cut up cookie sheet
Timing Marks ??? Zeder Engine 10 06-18-2013 04:19 AM
What should my timing be set at? chevyelc81 Engine 1 08-06-2004 04:11 PM
Using Wheel Scales To Set Preload BillyShope Suspension - Brakes - Steering 8 04-20-2004 06:35 AM
Degree wheel setting my cam timing 70 nova Engine 8 04-13-2003 01:08 PM
All a matter of timing with BBC and an EFI? vernw Engine 13 01-20-2003 04:26 PM
