setting camber/caster - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2012, 08:04 PM
This may sound like a silly question but, I am splitting the wishbones on my 28 model a and installing a 4 in dropped axel.The instalation instructions say to set it at 6 or 7 degrees.My question is this..with a magnetic angle finder set on top of the axel ,do I want it to lean back toward the rear of the car or forward toward the front of the car?
Old 07-18-2012, 09:04 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
That is the kingpin angle..So you will need to measure that..I just place a kingpin in the axle boss and put my angle gauge on that..
The top of the king pin is toward the rear..
Sam
Old 07-19-2012, 12:20 PM
setting caster/camber
Thanks for the reply, that answers my question.
Old 07-19-2012, 02:09 PM
You also mentioned camber, that on your model A can't be adjusted without bending the axle. Camber is the tilting of the wheel in or out at the top.
caster?camber settings racer57 Suspension - Brakes - Steering 7 01-19-2012 05:59 PM
Caster/Camber Gauge steve392 Suspension - Brakes - Steering 1 11-28-2006 06:51 AM
Caster--Camber Bryan59EC Suspension - Brakes - Steering 14 07-22-2006 08:50 PM
Caster and Camber bigiron40 Suspension - Brakes - Steering 14 12-12-2005 12:20 PM
Caster and Camber WilderRods Suspension - Brakes - Steering 2 01-17-2005 02:05 PM
