Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - setting a carb for e85?
Old 01-19-2007, 10:11 AM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is offline
Race it, Don't rice it!
Yes exactly, the same timing.
Gas, alky, methonal, E85, nitro, whatever, I've have, or my buddies have used it all these at some point. 36' timing
If your using race gas then and moving timing your wasting money. Octane does NOT make power. Compression does.
Your from Sweden, and not here in the land of the free, so I can't tell you about your carb since your fuel requirement's are not the same as ours.
I can tell you that when you switch to our street gas to E85 my carb builder, I might he is the best in the buisiness, will charge you close to $1000 to convert.
