Setting Carrier Bearing Preload - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2012, 06:48 AM
I WOULD LIKE TO KNOW THE CORRECT PROCEDURE FOR SETTING CARRIER BEARING PRELOAD. WHEN I TOOK MY 12 BOLT PASS REAR APART TO R+R THE RING+PINION. THE CARRIER BEARING SHIMS WERE ALMOST CHEWED IN HALF BY THE AXLE. THANX
Old 05-19-2012, 02:59 PM
GMC boogie's Avatar
Its a feel thing. You dont want to beat the carrier in but you also dont want it to fall in.
Hydraulic Roller Lifter Preload Setting Gilliaml Hotrodding Basics 1 02-19-2012 04:22 PM
Ford 9" Carrier Bearing Preload Help dsmith1279 Transmission - Rearend 3 07-30-2007 01:40 PM
Problems setting hydraulic lifter preload - please help Mad Maggot Engine 9 08-23-2006 02:30 AM
Pulling my hair out setting preload... sizemoremk Engine 13 03-16-2006 11:32 AM
Carrier bearing preload? Sixshooter Transmission - Rearend 11 11-10-2005 12:35 PM
