Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Setting Ignition Timing?
Old 12-14-2010, 05:10 PM
andythedrummer's Avatar
andythedrummer andythedrummer is offline
engine timing
Hi, The best hay to set your timing is,#1 put your lite back in your toolbox,grab your vacume gage connect it to manifold for main vac.with your engine up to temp,ajust your dist,to try and get 18 inch of vac, this is the only way I know if you dont have any specs for the cam. If it sounds like its pinging back it off just a little
