Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Setting Ignition Timing?
Old 12-17-2010, 05:34 PM
StockR's Avatar
StockR StockR is offline
Yeah, you guys were right... it's points. I don't know what I was thinking.
Anyways, Frisco, The block is from a 1980 Chevy truck I believe. So with the specs you listed for the original stock 69 block do those also pertain to the 1980 block as well? I can look for the casting numbers if you want?
