Setting My Thrust Bearing and Clearance / Ford 289 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2008, 11:09 PM
Hello folks,
I have tom monroes book and understand the process to seat the thrust bearing. I have pryed the shaft for and aft several time and even rapped on the front and rear of the crank with a block and hammer. I am checking clearance with a feeler guage. Tom Monroes, How to Rebuild your Small Block Ford, says to pry the crank forward then check clearance. Should be .004-.008. The most I can get on either side is .003 with the other side being .0015 at the same time. Total clearance is .0045. I am thinking the assembly lube is what won't let me get it any farther forward or aft.
So am I good with a total of .045, or does it have to be at least .004 on one side?
Thanks.
By the way, I have all the caps torqued to 65lbs and have set the thrust bearing, loosened now to finger tight. I believe I am doing things correctly.
Old 05-26-2008, 12:59 AM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Your clearance of .0045 is perfect, and shows almost zero wear on the thrust surfaces of the crankshaft. If the crankshaft's thrust surface is smooth and flat you will not have any problem with this clearance.
Stephen
just my 2 cents worth
Old 05-26-2008, 07:51 AM
Thanks saavy...
Just to feed my obsessive nature though, again, it is total .0045.
.003 one side and .0015 on the other. And yes i had the crank polished and balanced and my guy said it was in excellent condition. Std bearings.
So i'm good, just want to make sure?
Thanks again.
Old 05-26-2008, 08:48 AM
Alright, just went outside and gave the crank a couple more raps and a good pry and I was able to get the.004 feeler in the one side.
Think I'm good. Torqued everything up. On to the pistons.
Thanks again.
main bearing clearance GMR Engine 10 05-31-2008 10:16 AM
Checking rod bearing clearance problems mrdreex Engine 13 04-05-2008 06:06 PM
My 383 Buildup, Main Bearing Clearance cobra621 Engine 8 09-25-2005 04:49 PM
High side bearing clearance?? chevyelc81 Engine 1 05-04-2004 12:25 PM
excessive bearing clearance KeithB123 Engine 5 09-18-2003 11:12 PM
