Setting Pinion depth - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2011, 02:48 AM
67 camaro,
Is it necessary to pre-load the pinion to specks prior to setting pinion depth?
Old 04-28-2011, 03:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Nasty 67
67 camaro,
Yes. I use the old crush sleeve that has been 'lengthened' a bit by tapping it around its circumference w/a small ballpeen hammer. Use the old pinion nut as well (I use a 'regular' non locknut-type nut from NAPA for this so the nut threads on freely). Oil the bearings w/motor oil, leave the seal out for now, and tighten to the lower side of the preload specs.
Old 04-28-2011, 09:51 AM
prostreet6t9's Avatar
Differential/Driveline
Leave any crush sleeve and pinion seal out during the set up process.Keep your preloads correct and the same when doing any changes.
YES you need to preload the pinion.
GM 12 bolt Pinion Depth mycars51 Transmission - Rearend 9 05-01-2009 09:01 AM
pinion depth eatonde Transmission - Rearend 7 12-22-2008 12:36 PM
Questions on pinion-depth and play deuce_454 Transmission - Rearend 2 05-14-2006 05:15 PM
Pinion depth guage johnnya Transmission - Rearend 8 11-03-2004 05:42 PM
Setting Pinion Angle? 41willys Transmission - Rearend 5 11-09-2002 09:37 PM
