setting points, quick question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2010, 08:33 PM
Jeff J's Avatar
hey guys,
I know this has been covered, just need a quick answer and simple, don't want to hog the boards with this. When you install your points from the box, do you set the initial gap with the lobe peek of making full contact with the points or with the flat part and really no contact. Looking at .016 to get in the ball park but not sure what position the points need to be in before setting this gap? Yes, as soon as I get this engine running again, I am going to switch over the an electronic system... thanks in advance,,,, Since nobody hardly use's points anymore I am having trouble with this. Jeff J. Its for a 69 Camaro with a 350 engine.....original points and condensor set up still in car.. thanks
Old 07-28-2010, 08:59 PM
poncho62's Avatar
Wiki Edits: 5
The cam lobe of the distributor opens the points, so you set it at 16 thou on the peak ......If you set it on the flat part, they would be open all the time.
Ontario Rodders
Old 07-28-2010, 09:06 PM
points
Set the point rub right on the high points (corner) of the cam on the distributor. I've used a matchbook cover to get real close to the correct gap at the electrical contact. Tighten it down. Engine should start. With the engine running, use your 1/8" allen wrench (or whatever size it is), and turn it clockwise until it misfires. Back it off 180 degrees(half turn), and it will be very close to spec.
289 ford vs 283 chevy?? Jeepracer427 Engine 76 09-19-2010 07:38 PM
setting points on sb chevy frackster66 Electrical 14 03-22-2008 11:33 AM
setting the gap on a points type dizzy... makes me dizzy... JJ350 Electrical 6 04-04-2007 02:55 PM
setting the gap on a points type dizzy... makes me dizzy... JJ350 Engine 6 03-27-2007 03:33 PM
Quick question on timing an engine? ATMRacerTX Engine 8 12-17-2003 01:00 PM
