setting ride height for suspension swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2006, 05:21 PM
Last journal entry: another side shot
Hi; I would like to install a gm 12 bolt from an olds 442 into my 52 benz. The benz came w/ an IRS, and a corvette rear would be easier to install, but I want to use the parts that I have.
I think I would need to set the desired ride height and axle location before I try to locate the trailing arm pick up points.
How do I set frame ride height? is there a standard that people are using? Thanks Jimmy R
Old 12-20-2006, 08:07 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
A shop manual or body manual for the car would list the specs of frame height from the ground.
That's if you want stock ride height. You can alter it however you wish since you have a clean slate.
Old 12-20-2006, 10:44 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
What I do is block the car to the desired finished ride height and then I can determine just how to do the attachment points for the suspension
Minimum ride height is considered to be the height of the tire sidewalls..Of course if you are running some of the 35/40 series sidewalls that is really low..For a normal street car somewhere in the 6"-8" range to allow enough ground clearance to get over speed bumps and up and down drive aprons and such..That is measured from the bottom of the frame rails..
Other than that go for it..
Sam
Old 12-21-2006, 10:25 PM
ride height
Thanks for the info. I will set between 6 and 8 inches, maybe add a little rake then take some pictures to see what looks good. Thanks for your help
Increasing Ride Height Slightly - what are my options? hduff Suspension - Brakes - Steering 8 10-19-2004 07:44 PM
Ride height 1937 ford pickup magnum2u Suspension - Brakes - Steering 0 08-21-2004 05:02 PM
problem with ride height!!! brian400ex Suspension - Brakes - Steering 3 04-17-2004 04:22 PM
Hydraulics vs. air ride flamedfordbronco Suspension - Brakes - Steering 16 01-24-2004 08:46 PM
raising rear ride height 67_Deuce Suspension - Brakes - Steering 5 01-18-2003 10:19 PM
