setting up a 4baron a 9in ford rear end in a 32 fo - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2012, 10:59 AM
setting a four bar up on a 9 inch ford rear end in a 32 ford coupe that has the body raked and channeled 5in down over the frame
Old 03-03-2012, 12:00 PM
rick 427's Avatar
Last journal entry: 33 WILLYS
Is this a question....or a comment??
Old 03-03-2012, 12:08 PM
Irelands child's Avatar
Yep - sounds good to me. That's "standard equipment" equipment on a '30s based street rod. So mister first poster, what do you want from us?
Irelands child
Old 03-03-2012, 01:43 PM
Most 32's built in the past few years have a 4 bar. Lots of different ways to do this.
The Body dropped over the frame and raked has NOTHING to do with the 4 bar.
setting up the rearend so it transfer the weight to the rear tires TATAs 57 Suspension - Brakes - Steering 10 07-21-2010 10:21 PM
Ford 302 marine motor timing setting. digithead1 Engine 0 05-26-2009 12:53 PM
Setting up a Ford 312 Y-block 57ford_fairlane Engine 85 09-05-2007 05:39 AM
Setting up Ford Rearend under a new frame Big Daddy Suspension - Brakes - Steering 3 01-12-2006 07:50 AM
Setting timing on Ford 460 cboy Engine 7 06-30-2004 12:30 PM
