Setting up a "new" computer - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Off-Topic
Old 10-29-2013, 12:58 AM
Semper Gumby
Wiki Edits: 2
Well, after I toasted the mobo in my laptop, it was time for a new one. Every one I looked at, had Windoze 8 and I'd do without a computer at all before I'll subject myself to THAT censored mess again!
So I scored a (supposedly) lightly used one and brought it home, W7 system & all. It has everything I want - W7, an AMD chipset (instead of Intel) a big screen, 64 bit system, humongous hard drive, etc
Now for the fun part
So far I have uninstalled 42 games, uninstalled Google Chrome, uninstalled 2 other web systems, installed Firefox, uninstalled, deleted and removed all the pictures files, audio files, video files, the camera, the microphone and the speakers. Next to go will be Netscape Navigator. MSN mail (formerly called hotmale) is now gone, and I am looking for a good replacement for Yahoo mail - which is now emulating G-string - er, I mean Geemale and is annoying the crap outta me on any machine. Trouble is, I need an e-mail that is accessible from anywhere, not just at home, or on my local servers.
When I find a good e-mail, it will go on all my computers, but in the meantime, I'm thinking it will take another day or two of uninstalling and (in some cases, like the camera, microphone and speakers), physically removing stuff to get this li'l beastie to where I want it to be.
Old 10-29-2013, 07:20 AM
Banned
well since you do not want msn, or yahoo, or the g thing. or local. you can use AOLmail.
Old 10-29-2013, 10:41 AM
Fang16's Avatar
Last journal entry: Project change
Why didn't u format it and start out with a clean disk? No telling how much junk is left on it n in the registry. Even with a clean install I like to use Glary Utilities to keep it clean.
Old 10-29-2013, 10:55 AM
ogre's Avatar
the 'Duracell Project'
i'd format the hd too. easy peasy. if you don't have discs there might be a partition with the install files
Old 10-29-2013, 10:58 AM
Fang16's Avatar
Originally Posted by Denny View Post
You might have good luck with that, but, have you read a lot of feedback using that application ???
Been using it for 4 years and never a problem. Some people have a couple of different reg cleaners that they use n that's what causes a problem. Not to mention that a few anti-virus systems are a joke.
Old 10-29-2013, 07:15 PM
Semper Gumby
Wiki Edits: 2
What I need is a computer that can do a LOT of WORD Documents, presentation docs such as POWERPOINT, a lot of EXCEL and a lot of chart & graph-making stuff. It needs to be able to pull data from many sources, in multiple formats and compile the data without my having to print out a report prepared in one format and re-key it into another. Then it needs to feed a projector for me to present my stuff to the clients.
So far I am finding that I start to have things get noticeably slower if I use less than 640 G of RAM and unless I run a Tb of disc, I am spending too much time swapping out media.
I do not want, nor need any music, or videos, nor any "keep an album of pictures from my last vacation".
My computer needs to be able to websurf for research, run several programs at once and then transmit the proposals, contracts, reports, briefs etc. to other consultants or directly to a client
Yahoo mail was ideal until they "improved it" within the last month to where it now thinks every e-mail between me and a client is part of one extended "conversation" and repeats the "entire conversation" as a part of every e-mail I send to that client. (including attachments as originally attached to "that" note, etc) Now it can take a humongous amount of time & bandwidth just to send one e-mail. If I am using my cellphone as a "hotspot", the charges add up into the OMG range in a second or two.
Giggle's G-String - (GMale?) is just as stoopid and the microsquish system formerly known as Hotmale is just plain dumb
My issue right now is that I am looking at changing providers for Net & phone and (etc) and don't want to send out a "change my e-mail to......" notice and then maybe send another later if I gotta change it again.
Old 10-29-2013, 10:17 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Hi Dave.
Are you using Telus for your regular e-mail? (I see you are from Vancouver)
If so, they do have a webmail interface. https://webmail.telus.net/ which you can use to access your e-mail from any PC on the web.
That being said, you'd probably want to configure your "regular" e-mail program to leave a copy on the server to allow access to "read" e-mail messages.
As far as the multi-program re-typing goes, I have found a program called "Able2Extract Professional" to work very well at converting and OCR-ing PDF files into Excel, Publisher, Word, Powerpoint, etc.
I'm VERY impressed with the "automatic" setting, and the OCR is very accurate in most cases. I'm running version 7.0, and I see that a new version has now been released (8.0)
Best of luck ...
The Following User Says Thank You to 66GMC For This Useful Post:
Dave57210 (10-29-2013)
Old 10-29-2013, 10:33 PM
66GMC's Avatar
I may increase to a i7, but it seems that things are working fine, with several things opened at once, so no hurry in that area yet. I also use a drawing tablet, which seems to work well also.
FWIW, I'm running an Acer Predator G5910, i7-2600@3.40 with 8GB of ram, and my scores are not all that much better than yours.
7.6 on the first two , 7.2 on the second two, and the same 5.9 disc access,
which appears to be the bottleneck.
Old 10-29-2013, 10:56 PM
Semper Gumby
Wiki Edits: 2
Originally Posted by 66GMC View Post
Hi Dave.
Best of luck ...
I'm actually on SHAW right now, but this is not cast in stone (may change to Telus)
Shaw also has a Webmail interface, but I've not heard a lot of good things about it. (Actually - "would all Shaw customers who are happy with ANY of Shaw's offerings please stand on this 1 inch square?" )
If the use of the Webmail interface will allow me to access my e-mails from other parts of the world, then a lot of my issues are fixed! Thank you! You have opened a new perspective for me!
I have never tried a webmail system - in fact I've never even used the Shaw e-mail addresses (nor interface). Shaw keeps calling me and wanting me to add my home phone onto my current (Internet plus TV) plan, but when I call their tech services to set up a Shaw e-mail account, THEIR phones are out of order! Yup, sure makes me want to have my home phone on their system! (Trust private sector to do the General Motors thing and cut costs to where nothing works! At least Telus used to be gov't so you know it will work!) (and Telus is making HUGE profits so they'll be around for long time)
Old 10-29-2013, 11:02 PM
Semper Gumby
Wiki Edits: 2
Forgot to say - my "new laptop" is a Dell Inspiron, hotrodded with a new MoBo based around a Phenom X4 64 chipset and 8 G of Ram plus 1 tb of HDD
Now if only I could stop dragging my shirt cuff on the touch pad and moving the cursor all over the screen, causing my typing to go all to schizzle!
Luckily, I have a plug-in "regular" keyboard that I will take with me when I go off with this thing.
Old 11-03-2013, 11:54 AM
66GMC's Avatar
I bought an i-Pad a couple of years ago, and later purchased a bluetooth keyboard & cover to go with it.
I really like that bluetooth keyboard, and use it with my i-Phone as well.
It's WAY better than having to use those tiny on-screen "keyboards" for things like texting and e-mail.
I've been on Telus (residential phone, "high-speed" internet, and cellular) for a number of years now. The only real complaint I've had is the account password issues.
I call it "Password Hell" as there is no way to be reminded of a forgotten password ... you HAVE TO create a new one ... and CANNOT re-use a previous one. Whose freaking account is this anyway? Grrrr!
The town of Olds has recently been upgraded to THE fastest internet (1 GBps) on the continent, by a community-owned company called O-Net.
Yup, a population of 8,000-ish, and only Altanta, Georgia even comes close to the service we are being offered! The fibre-optic cable has been installed in most of the town already, and many are already subscribed.
It is supposed to be installed in my neighborhood next spring ...
Old 11-03-2013, 01:36 PM
AJL Electronics's Avatar
The ultimate answer to email addresses is to have your own domain name. That way, you can change ISP as often as you like and your email address is just pointed at the current ISP. Most hosts have a web interface if you need that facility.
Strange thing happening with my clear "solvent pop"/"fish eyes" ? myfamiliacc Body - Exterior 35 02-16-2013 07:18 PM
SpeedypcPro "computer fixer" bullheimer Off-Topic 1 07-13-2012 05:59 PM
How to run an "01" FI Motor without Computer? waltrobak Electrical 2 12-19-2011 01:15 PM
wiki pages: "How to rebuild an engine", "Window removal/installation" Jon Hotrodders' Lounge 0 07-11-2006 12:44 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
