setting up a paint gun,the right way - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2005, 07:53 PM
70Shorty's Avatar
Bob
Lets start with the compressors psi ?? I'm useing a sucksion gun whats the psi at the gun?? I'm useing primer now, what to set at when shooting paint??
Old 04-03-2005, 08:47 PM
The tech sheet for your primer should have a recomended air pressure and fluid tip size for your gun. What kind of primer? What model gun?
Old 04-04-2005, 10:41 AM
70Shorty's Avatar
Bob
The gun is a cheap one from alltrade,I use it for primer. The thing is ,I guess I need to know how to read the gauge on the reg., the one attached to the gun.I 'm just not getting it right. I have the compressor set at around 45-50 lbs. But reg. is screwing with me.
I'm getting ready to shoot some high build, dura-build from evercoat.
I just shot the box with etch from eastwood. Should I go over it with epoxy ??? Before I fill???
Lots of beginners questions
Bob,
Old 04-06-2005, 12:46 AM
I always shoot my dura-build (acrylic laquer primer) with about 45 PSI at the gun, with my HVLP but with a siphon feed you might want to check out your manual for the maximum recomended PSI and work down from that untill you get the desired results....make sure you are pulling the trigger while setting it for 45psi or w/e because It will drop. also siphons usually have a higher required psi than HVLP (or at least mine did) and set your tanks regulator to about 80 with the trigger pulled. for my primer gun (and bascoat/clear gun for a long time) I use the purple HVLP from harbor freight...its a GREAT gun for the money and has little overspray compared to a siphon feed. I bought mine for 50 bucks on sale I think it was the 43440 or something like that. Might need a new regulator too.
Old 04-07-2005, 09:11 AM
70Shorty's Avatar
Bob
Thanks for the info,, I'll give it a try, with your suggested settings,,
Thanks again,,,,
Old 04-08-2005, 03:05 AM
no problem let me know how it works out for ya
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 33 07-08-2011 01:33 PM
Sherman Williams Clear Coat Failing < 3 Years? DeJarnett Body - Exterior 33 12-11-2005 11:39 AM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 07:31 AM
Need color/top ideas.... Cracker Red Body - Exterior 4 09-07-2004 09:14 PM
