Yep seems as if your math is bang on and those values are actually pretty good,
I am curious as to what type of HEI this is, is there a vacuum limiter plate in there? when you say that you are adjusting the vacuum adv I assume that you mean the set screw inside the can? what is the full engine vacuum at idle with the can connected? the set screw will only load up the internal spring so it effectively shifts the range up, but when you come off the gas lets say and pull more vacuum than at idle or at mid unloaded rev it will advance more than you are seeing at idle cause your pulling more vacuum. I have always use a limiter plate inside the HEI to limit the allowable travel of the vacuum adv push rod, this way you are sure it will not go higher cause it lessen's the travel. Example; the total travel of the rod is say 1/2 inch and 1/2 inch adds 20 deg advance when a vacuum pressure is applied from 6 to 14 inch hg" thats an 8 hg" range to get the 20 deg adv the motor pulls say 14 hg" at idle. now tighten the spring as you are doing, this raises the starting point of the movement to say 10" but it does not effect the total amount of travel available, it will still want to move 1/2 inch when the vac goes up but this time it will have to get to 18 hg" to give the 20 deg adv. and since it only see's 14 hg" it only adds 16 deg adv lets say. So without a limiter plate in there you are only changing the the starting point of you vacuum adv, the only limit being effected is that your idle and mid rev vacuum is probably not enough to pull it in all the way, but if the engine vacuum goes up due to deceleration lets say and reaches 18" vac the can will still add 20 deg at that point. This is the way that my particular HEI works and it will apply to most but not all HEI distributors. Hows that for a disclaimer
Well I don't know how to check the thing while I am driving it even if I hooked up my vacuum gauge. I don't know how much travel it has. The only way I know of checking is the numbers at idle and reeving it that's about it.
My vacuum at idle is about 18-19 inches. The gauge was steady but I have a stupid misfire that keeps happening and makes it drop just .5 of an inch of vacuum. I have checked plugs wires cap, coil and ground and everything else before and just can't figure out what is causing it. I guess there is more then what I have already learned. I don't know about limiting travel of the vacuum canister. The hei I have is a summit hei that I got cause of the melonized gear it has. Eric |
http://www.summitracing.com/parts/CRN-99619-1/ The miss fire is most likely not related to this senario but you are on the right track by going through the ignition checks to try and rule out that part of it as the cause. Does the miss fire happen at all times including idle and actually driving? |
Well I had a previous post about the miss fire and could not come up with anything. I have had different plug wires, complete distributor change along with the coil, cap, rotor, and control module and no change. I have also checked all my wires and ground wires and added extra ground and am getting proper voltage to my distributor as well.
I originally thought it was part of the overlap of my old cam but after the cam swap and everything else the dam miss is still there. It does not really seem to be there while cruising but at idle you can't miss it. The idle will be nice and smooth and then it will cut out and start to get rough then smooth out again. I have checked for vacuum leaks but as far as can tell there are none. I have plugged my vacuum hoses and went through everything and still its there. The worst time you hear it is when the engine is cold and on first start up it will be smooth miss then smooth again and you can tell when it does a cylinder drops and picks back up. I even just replaced the plugs again. I also tried the idle mixture screws and tried to adjust them and it really did not change anything. I am so sick of this engine I just want to through it out to the scrap yard. I have done everything to it and always just have to have something to not work good on it. I even took my plug wires and checked them for fire as the motor was running and they all fire just fine so go figure. But on the limiter plate I might get one but I still have not had any issues with pinging or anything so would I really need it? Thanks again for help. Eric |
If you can get a vacuum pump and connect to the vacuum can with the engine running and the hose plugged. Vary the pressure using the pump and note at what pressure you reach maximum advance. I bet the pressure needed to reach full advance is higher than the vacuum your engine pulls. This is because you have the adjustable screw in the can all the way out raising the starting pressure of the movement. A rule of thumb is to have the vacuum advance all in at about 2 hg" below your nominal max engine vacuum level or in your case all in by about 15-16"hg |
Well I did buy a accell 31035 vacuum advance canister that says you can limit the amount of advance you get and the travel amount . I have not installed it caused I guess I am a little confused on the instructions on the chart they give. Maybe you can help me out if you wish.
http://www.accel-ignition.com/pdf/31035.pdf Eric |
If looking at that chart if I turn the allen wrench about 4 or 5 turns from the stopped position then it would give me around 12 to 13 degrees of advance and no more then that correct? I guess I don't know why there vacuum advance canister would be any different then all the other ones you can get from jegs and summit. I don't have a problem getting the plate heck its only 4 bucks
![]() Eric |
The problem is you hooked it up to "Manifold Vacuum", the vacuum advance is suppose to be hooked to a "Ported Vacuum" port on the carb that doesn't have vacuum at idle.
What happened is when you hooked the vacuum advance to "manifold vacuum" it pulled the 10 degrees in that the vacuum advance advances, which raised your idle and thus kicked in the mechanical advance and that is why you had 40 degrees of advance at idle. Just hook up the vacuum advance to the ported vacuum port on the carb. And that should fix the problem. |
Yes I think the accel unit is advertised as something different than what you have in there already, according to the graph it is a limiter and the set screw is used to set the limit and not the start point as in a typical adjustable can. Test it with a gage and see if changing the set screw changes the rod travel or if it just adjusts the start and stop "hg. curious Quote:
Ported vacuum is not the answer to every ignition advance problem, so please don't come on here with an empirical answer like you gave. |
Anyway his first action in this case would be to hook the vacuum advance to the ported vacuum port on the carb. That way he will stop the vacuum advance from pulling in all that timing at idle and make it work like it was designed to. Put it this way I was a ASE master certified mechanic for 10 years and have been building and tuning engines and hot rods for the last 25 years. I think I know a little about the subject at hand.
As far as I know most vacuum advances are good for about 10 degrees of advance. So if your trying to limit it to even less advance than that, then why even run one?? Then there is the fact that once you nail the throttle to WOT, the vacuum advance will stop pulling in advance(timing) since vacuum at WOT is very low. So at WOT the only advance you'll have is your mechanical advance. Vacuum advance is for part throttle driving.......... |
I was looking at the big picture and taking it step by step, my point thoughout was that the limiter is needed to ensure that he can set up the dist to have it all in at idle and that it won't add any more if the engine vac increases, also we don't want the vacuum can rod to be floating around, we want it to be pinned at its max travel at idle. His 30ish deg advance at idle is a good place to be with his setup, he could even use a bit more perhaps and yeah we don't want any mech adv at idle but i doubt that is going on cause he's got 16 base + 14-16 vacuum adv that accounts for his idle timing at 30-32. Quote:
Sorry I got a little confused here, thought we were talking stock HEI and didn't realize we were talking about an Accel HEI. Ya depending on how far you turn the screw in the vacuum canister, will determine how much advance you'll get out of it. 7 turns will give you full advance, where 3-4 will give you about 10-12 degrees. This is starting with the adjustment screw turned all the way out counterclockwise and then turning it in clockwise the number of turns stated.
But I don't understand what any of this has to do with you having to much advance at idle. I guess before I opened my big mouth, I should have asked a couple of questions. One, what do you what the timing to be set at Idle with the vacuum advance connected?? Two, how much advance do you want from your vacuum advance?? Third, have you tried setting the base timing at 16 degrees and taking the car for a drive with the vacuum advance disconnected?? You see the problem is your referencing the vacuum signal from the wrong side of the throttle blades. On the manifold side vacuum is highest when the the throttle blades are closed, but as soon as you crack the throttle the vacuum in the intake manifold drops and so does the amount of advance the vacuum advance is adding. Do instead of advancing your timing as the throttle in opened it actually retards your timing as the throttle is opened. That is why your suppose to hook the vacuum advance to a ported vacuum port on the carb, it is a port that doesn't see vacuum until the throttle is cracked. It is the way a vacuum advance was designed to work. |
| detonation | 71 chevy c-10 | Engine | 33 | 04-29-2010 12:20 PM |
| Edelbrock 750 tuning | GCD1962 | Engine | 42 | 04-16-2008 06:03 PM |
| 68 charger lights | T-bucket23 | Electrical | 5 | 08-14-2006 05:07 PM |
| ignition timing | bad502 | Engine | 21 | 02-20-2006 06:57 PM |
| mechanical advance settings?? | Lthompson | Electrical | 10 | 02-10-2005 03:19 PM |
