setting valves solid cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2009, 06:05 PM
We just had a big block built and was supposed to get together with the builder and he was going to show us how to set the valves. We couldn't seem to get time to have him show me and all i've ever messed with are hydraulic cams.
He did say to set it at 22 cold. All the info I got. Can someone please cause i know there out of adjustment tell me a simple way to adjust these right. Thanks
Old 10-22-2009, 06:14 PM
airboat's Avatar
Here's a link! Adjust away! and if he wants 22 cold that refers to .022" clearance between rocker arm tip and valve stem. .022" Feeler gauge
http://www.centuryperformance.com/ad...h-spg-149.html
Old 10-22-2009, 06:23 PM
DoubleVision's Avatar
Try this thread:
http://www.chevelles.com/forums/show...ght=eoic+kjett
Old 10-23-2009, 05:43 PM
remote starter
get a remote starter,remove coil and ground it,, and adjust the rockers just as it goes through tdc and any other rockers on the firingg order,, if you intall a stud girdle,the poly locks will stay tighter longer,,,make sure you have the right clearenc e specs from manufacter,, after a few settings you will be a pro... i say set them hot,,, if they are alluminum heads i would for sure set hot because they expand a lot on heat up....
Old 10-23-2009, 07:27 PM
Thanks
hey f-bird this is the eoic method i read about/ When your done with the #1 cylinder can you just move to 3 5 7 and then jump to the other side and 2468? Appreciate the help. My builder said to set them cold and yes they are aluminum heads and a setting of .022. why would you do it warm is that a better way? Trying to learn so lets hear why?
Old 10-24-2009, 08:48 AM
When valves are specked hot what id is set at .002 loose(iron block and heads) warm the engine up to operating temp set one cylinder.Then go to the house till the next day and check the lash on the cylinder set hot this becomes the cold setting and never have to do it hot again.
Hyd. Roller lifters on Solid roller cam danrace1 Engine 6 01-28-2010 06:21 PM
Howards Cams Greg T Engine 21 10-04-2009 01:28 PM
Using solid cam driven EVERY day?? Warrant Engine 19 02-19-2007 04:28 PM
what are the power gains from a solid lifter cam on small c.i. sbc 74chevyflat Engine 4 06-08-2006 07:49 PM
Poll... on the sound of solid VS hyd cam sound. Blown72Camaro Engine 12 05-28-2004 06:56 PM
