setup on a winters Q/C - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2007, 07:15 PM
Bad Rat's Avatar
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
Winters Q/C locker install
Hi Guys,, I hope some body out there can give me a bit of infromation on setting up a detroit locker in a winters Q/C carrier,, I have never set one up before,, The locker has bearings on each side that fit into races that are installed in the side bells, and are held in by bolting the side bells onto the center section,, there is a rub block adjustment [ so to speak] that can be adjusted to hold the locker centered. against the bells { I think this is how its suspose to work,, anyone know about these things.. any special clearances or anything? I have checked the winters website but there is no infro there,, Thanks Bill
Old 09-14-2007, 02:15 PM
novajohnb's Avatar
It'll go, or it'll blow...
How to adjust "ring gear wear pad" straight from Winters:
Run wear pad in against the ring gear with a force of 5 in lbs, back off approximately 1/4 turn to obtain .008 to .010 clearance between ring gear and wear pad. Tighten jam nut on adjusting screw being careful not to turn adjusting screw any further.
If I'm reading your initial post right, you also will need to adjust the carrier bearing preload and gear backlash.
See the attached for FAQ and setup instructions form Winters.
The instructions actually *are* on the Winter web site, buried in the catalog.
Name:	quick change setup1.jpg
ID:	24220   Click image for larger version
Name:	quick change setup3.jpg
ID:	24221   Click image for larger version
Name:	winters rear FAQS page.jpg
ID:	24222   Click image for larger version
Name:	quick change setup2.jpg
Old 09-14-2007, 08:04 PM
Bad Rat's Avatar
Wiki Edits: 2
Thanks Nova john I did pull up the winters FAQ thing,, but when I tried to access that page in the catalog,, it told me I was not authorized to access it,, Anyway,, thanks fior this infromation,,, its exactly what i was looking for, I'll save these attachmebnts to my puter.. Bill
Old 02-01-2010, 07:54 AM
Bad Rat's Avatar
Wiki Edits: 2
Anyone have any information on how to set up the gears on a Winters Quick change rear end;
Old 02-01-2010, 11:44 AM
www.wintersperformance.com
Old 02-01-2010, 03:24 PM
Bad Rat's Avatar
Wiki Edits: 2
That site just has catalogs,, I know how to ste it up just need some spects
EDIT this should piss off some of those guys over at the HAMB posting this On here
http://www.jalopyjournal.com/forum/s...d.php?t=225131
Old 02-02-2010, 10:30 AM
novajohnb's Avatar
I answered a similar question for you in 2007. See the attachments in the link below:
http://www.hotrodders.com/forum/wint...ll-124319.html
Have you been working on the same rear since 2007? Don't feel bad- I've been doing body work on the same car since 1993!
Old 02-02-2010, 12:04 PM
Bad Rat's Avatar
Wiki Edits: 2
Yep!! still trying to get-er-done.. actually the project has been on the VERY back burner for way too long,, but finally scraped up enough $ to finish the car,, 48 Anglia Thames Panel, hopefully to have it going by next summer,, thats a BIG Hopefully,,,,,,,,,,,,,
I tried to find this post, but appairently I didn't dig deep enough,
Thanks John, Bill
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
My 9inch rear end disc brake setup. 1937FordCoupe Suspension - Brakes - Steering 0 01-15-2007 06:01 PM
Is my Torque Converter too big for my setup ?? 74NovaRat Engine 15 02-01-2005 08:23 AM
Setup Question (already running) Got Squeeze Engine 3 12-14-2002 10:53 PM
