setup on a winters Quick/Change - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2010, 04:17 AM
I bought a used Frankland Quick change a few years ago and trying to get it together.
It came out of a dirt modified and was set up for wide five hubs and willwood brakes. I pulled everything apart including the axle tubes out of the side bells. It also had a spool in it and I would like to put a locker in it and convert it to Ford 9" style axles and use drum brakes.
Where is the best place to find parts? Really dont want to spend $800 for a new locker.
Old 02-09-2010, 09:31 AM
Try racingjunk.com for a used locker. Winters sells tubes with Ford9 housing ends installed and axles to match.
Old 02-09-2010, 09:39 AM
Bad Rat's Avatar
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
Mine had a spool in it also,, but I found a aluminum locker on E/bay,, and got it for around 350 $ just have to keep looking,, Racing junk is a good suggestion also
Old 02-09-2010, 06:57 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
bighotroddin;
i split off your posts to a new thread here... since you were basically asking - starting a new thread within a thread
