Seville caliper question(conversion) - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2009, 02:55 PM
Helped a friend with a rear disc conversion, after reading through the archives I'm thinking that the parking brake actuating arm ratchet assy. isn't working properly. On the drivers side when you manually rotate the arm you feel resistance, on the passenger side when you move the arm it moves freely and you never feel resistance like on the oposite side. The pedal feels soft the brakes do work but I'm thinking there may be something wrong with the adjuster internally? Any thoughts. Thanks, Eric
Old 09-29-2009, 05:15 PM
The parking brake arms must be actuated probably a good 20? times to make sure it's set. If not the pad will be too far away from the rotor, thus low brake pedal. Once it gets going you should be able to watch the piston start puhing on the pad. Start there if you didn't work the actuators good enough .
Brake MC vs. Caliper Height?? 71gtx Suspension - Brakes - Steering 1 09-23-2009 10:49 AM
79 malibu front caliper removal help wiser626 Suspension - Brakes - Steering 3 06-26-2009 10:35 PM
Wilwood caliper screwup-long 302 Z28 Suspension - Brakes - Steering 1 04-28-2006 08:07 AM
Taurus Brake Caliper...Slow Release. awbazar Suspension - Brakes - Steering 5 02-22-2006 05:33 PM
Disk brake caliper & steering arm hitting gator412 Suspension - Brakes - Steering 3 05-28-2005 11:31 PM
