seville rear calipers - any good? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2005, 09:59 AM
I'm in the planning stage of putting rear discs on my 69 Pontiac Le Mans. I've managed to get the whole brake set up from a 79 inc booster, master cylinder, distribution valve block etc.
My question is this - I hear mixed opinions about the seville calipers. They have the e-brake which is mandatory here in the UK and will bolt up with little rework to my existing axle, but they seem to have a bad rep for sticking etc. Why is this? Do they suffer from a design fault or similar problem?
Thanks
Old 09-25-2005, 11:43 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Personally I think those issues are primarily a maintenance issue..If well maintained they work fine..
OMT
Old 09-26-2005, 03:57 AM
I thought/was hoping that was the case.
I guess it follows a pattern like many other automotive reputations - new system introduced, different from previous, owners don't appreciate the new maintenance demands, ignore it and then blame the new system when it goes wrong.
Thanks for the input.
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
Rear ends... chrisflock Transmission - Rearend 12 06-04-2005 09:05 PM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
Using used rear end gears? good or bad Dubz Transmission - Rearend 5 11-17-2003 07:46 PM
How much $ for good body work Rad Ray Body - Exterior 11 04-17-2003 12:22 PM
