Sew Foam Compression? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2010, 12:25 PM
I read on a prevoius thread about sewfoam compressing once it is sewn down. I believe Dan said that he started with 11 3/16 inches on a panel and ended up with 11 inches. I believe the sewfoam was 1/2 inch. So is it safe to say that 1/2 inch sewfoam compresses 3/16 of an inch when sewn down?
Old 08-19-2010, 10:59 PM
DanTwoLakes's Avatar
Wiki Edits: 22
I don't think you understand what I was trying to describe. The "compressing" you're talking about is from side to side or top to bottom, and only when sewing pleats or channels into 1/2" sew foam. The insert piece I was doing shrank 3/16 of an inch from 11 and 3/16" to 11" side to side after having the pleats sewed into it. I knew that ahead of time, because I did a test with a small piece of the fabric and foam I was using.
The answer is no, it varies with different fabrics and different sew foams, and I would call it shrinking rather than compressing. That's why I recommended doing a test run with the fabric and foam you'll be using to see how much it shrinks before you lay out the lines and sew your finished pleats. Vinyl may shrink less than cloth, leather and Ultraleather depending on how stiff the vinyl is.
Replacing sew foam? Coodeville Interior 2 02-11-2010 10:54 AM
Dynamic Compression Ratio?? starnest Engine 3 04-27-2007 02:22 PM
dynamic compression 71javelin Engine 8 01-04-2007 08:22 AM
Foam foam and more foam Halloweenking Interior 20 06-07-2003 04:34 PM
How hard to do your own leather seats? stonedchihuahua Interior 16 12-17-2002 03:59 PM
