Sewing Machine... 350 SBC XR282HR Comp Cam with Lunati Roller Rockers - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2012, 07:58 PM
Motor has about 300 miles on it and i never really noticed but my engine sounds like a sewing machine. At first i feared it was a ring land, but a compression check showed that all was well.
Cam is a XR282HR, with LS7 lifters and Lunati Voodoo Rockers...
Im running procomp sheet metal valve covers and have plenty of clearance.
Preload is set up 1/2 turn past zero lash.
Is a sewing machine sound normal with an aggressive cam like this?
Its not terribly loud... i can hear it with the hood closed... but I can hear it with the hood open if i listen.
Old 08-01-2012, 08:04 PM
That sound is pretty normal with aftermarket roller rockers. I've heard it on every engine I've had with them. My solid roller sounds like that with the hood closed.
Old 08-01-2012, 08:21 PM
its not that loud that i can hear it outside... every once in a while if i bring it up to around 2500 rpm I can here it in the cab.
No misses, or carrying on... motor runs like a raped ape and moves my 4000lb pickup pretty good, pretty damn good.
Old 08-01-2012, 08:25 PM
As long as you tightened them down right I wouldn't worry about it. If it was super loud then you might need to readjust the preload but otherwise you'll be good. I've ran hydraulics a few times with aftermarket roller rockers, including a set of LS7 lifters, and they made that noise. I think you're good man.
Old 08-01-2012, 08:58 PM
thanks, ill try not to worry about it...
Old 08-01-2012, 09:29 PM
Banned
try a different oil and or viscosity
Lunati roller rockers eatonde Engine 4 02-09-2015 11:37 PM
Lunati Cam 00010LK vs Comp Cam CL12-242-2 hollingshedlr Engine 2 05-14-2009 07:47 AM
SBC 350 Roller Rockers colincamaro Engine 11 10-04-2007 02:22 PM
roller rockers for sbc 350 70ChvyNova Engine 4 12-06-2006 12:24 AM
Installing Comp Cam Roller Rockers on 5.0L Ford Motorsports GT-40 mikebmac Engine 2 07-23-2003 11:22 PM
