Sewing machine advise - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2007, 05:54 PM
Pudycat
Does the Singer 16-188 have a reverse? Does it have a clutch or servo motor (I assume it can be equipped with a servo if not right? Any other comments?
Old 10-09-2007, 07:00 PM
Dusty82's Avatar
Last journal entry: The Chevy Bench Seat - Part 52
Here's a couple of links for you. Both on the subject of the Singer 16-188.
http://www.get-up-and-go.com/upholst...ay;threadid=11
http://get-up-and-go.com/upholstery-...=3860.msg28533
Or, you could use my search yourself:
http://www.google.com/search?q=%22Si...L_enUS177US231
Doesn't look like it has reverse, but I may be wrong. Good luck in your search!
Old 10-09-2007, 08:57 PM
Pudycat
Google is a wonderful tool which we both used and the question of whether there is a reverse still remains.
Old 10-10-2007, 06:44 AM
DanTwoLakes's Avatar
Wiki Edits: 22
This machine would probably have a clutch motor. Any industrial sewing machine can be retro-fitted with a servo motor.
In most cases, they bolt right up to the original mounting holes. A clutch motor is either on or off, and a servo motor is a constant torque motor with variable speed.
As far as reverse goes, it is a nice feature to have, but not essential. If you're only going to do a little sewing, you can lift the needle, move it back on the seam you just sewed, and sew over the top of the original seam. The whole idea is to lock the end of the stitch line down, and this method will accomplish that.
Sewing Machine, Rex John Fehlberg Interior 12 09-14-2007 12:27 AM
DOH! Sewing Machine Revelation! - well, at least to me... Dusty82 Interior 17 08-29-2007 12:10 AM
Sewing Machine Troubleshooting ?. Barry.M Interior 26 07-25-2007 09:11 PM
Need advice on an ind. sewing machine TonyZXT Interior 26 02-18-2007 04:14 PM
Newbie With A Sewing Machine - Opinions Wanted Dusty82 Interior 21 02-18-2007 04:08 PM
