Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sewing machine issue??
Old 06-29-2012, 02:01 PM
SafeAirOne SafeAirOne is offline
I'll throw this out there as well:
If you 'reloaded' the bobbin, I presume you had to re-thread the top of the machine too, so I'd suggest that you check to make sure the thread routing is correct on the top of the machine as well. If the thread isn't going through the tensioner properly or through the take-up arm as it should, it'll ball up on the underside of the stitch/fabric.
