Sewing Machine Servo Motor Recommendation? - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 01-28-2013, 12:58 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Originally Posted by bentwings View Post
Thanks a lot for the info. Looks like I'll have to take the motor back out and check out this modification. Not a big deal.
Thanks Dan for the link.
I also will do a search for the tensioner. Might as well get it right from the start. They actually have a phone listed so I'll call Monday and order this. Free shipping too.!!
Here is the belt number I used....purchased from O'reiley's.. MasterPro V-Belt 7448 (15448) 3/8 x 45 3/8
Your situation as far as belt length will be different from everyone else, not everyone will be able to use that length belt. Here is how to measure for the correct belt for your machine: Look at post #14 in this thread: Reliable 3000?
  #77 (permalink)
Old 01-28-2013, 01:07 PM
Originally Posted by DanTwoLakes View Post
Unless there was another generation of the SewQuiet 4000, it does not have a digital display, only the 5000 has it.
Just what i thought because i didnt see any.
  #78 (permalink)
Old 01-28-2013, 01:49 PM
When I bought my machine back in 1989-90. I didnt know anything about industrial sewing machines or clutch motors. It wasnt until a few years ago I discovered they make two different speed clutch motors. One is 1720/1740 rpm, this is for heavy duty upholstery work. The other is 3460/3480 rpm and is used for light weight garment/sail making. My machine had the 3480 rpm clutch motor and it was like sewing with your sewing machine powered by a top fuel dragster engine. It was very hard to control and sewing straight lines was nearly impossible.
The new SQ5000 powering my Adler 267 is pure luxury. With the 50mm pulley I dont have to use the hand wheel to start or to stitch slow enough around tight corners, and it is still fast enough to sew long straight lines.
The Following User Says Thank You to beachbum jim For This Useful Post:
John long (01-28-2013)
  #79 (permalink)
Old 01-28-2013, 03:07 PM
Wiki Edits: 22
Originally Posted by beachbum jim View Post
. ".......With the 50mm pulley I dont have to use the hand wheel to start or to stitch slow enough around tight corners, and it is still fast enough to sew long straight lines.
The correct way to start sewing is by holding the thread with your left hand and using the hand wheel to penetrate what you are sewing. This prevents the thread from tangling or jamming. It is not a sign of weakness or lack of skill to use the hand wheel, it is there for a reason.
  #80 (permalink)
Old 01-28-2013, 07:21 PM
I Never said it was a weakness to use the hand wheel I just said I dont have too. Believe me I use it plenty. When I had the 3480 rpm clutch motor on my machine, I had to use the hand wheel alot. And yes I hold the thread ends, didnt think that needed to be said.
  #81 (permalink)
Old 01-29-2013, 12:03 AM
I use it all the time.
  #82 (permalink)
Old 01-29-2013, 07:39 AM
Wiki Edits: 22
I wasn't questioning your skill level or anything else, just pointing out to others who read this that don't have more than beginner skills with the sewing machine that avoiding using the hand wheel is not a positive and that there is a reason the hand wheel is there. You put the 50 MM pulley on your motor to slow it down 40%, and that's fine, but others who read this may not understand.
  #83 (permalink)
Old 01-29-2013, 07:46 AM
Thats cool... I see what you are saying.
  #84 (permalink)
Old 01-29-2013, 08:04 AM
Wiki Edits: 22
No problem. I did my math wrong, using the 50MM pulley to replace the standard 90MM pulley would reduce the sewing machine speed by 56%, not 40%.
  #85 (permalink)
Old 01-29-2013, 09:30 AM
I always read this thread with interest but have not posted lately because I did not feel I had anything more to contribute.
What I noticed most about changing to a 50mm pulley on my Adler 267 was the increased power at lower speeds. The smaller pulley does cut the speed in half but also doubles the mechanical advantage of the motor giving you much more control at lower speed. The machine will still run as fast as you will ever need.
Dan is the professional and his advise is always right on. I am just offering my observations as a guy who does his personal sewing and has made this change. It has really been a good thing for me.
  #86 (permalink)
Old 01-29-2013, 09:50 AM
Wiki Edits: 22
If what we are calling here a servo motor was a true servo motor, it would have constant torque throughout the entire speed range. True servos are used for precise indexing and positioning applications in industry.
The servos used on sewing machines are not true servos, so you are right that there is more mechanical advantage ( torque ) at lower speeds, and less at higher speeds.
  #87 (permalink)
Old 01-29-2013, 10:24 AM
Agreed. Even a true servo motor could benefit from a smaller pulley though. When you put a pipe on the end of a ratchet handle it does not make you any stronger. It only gives you increased mechanical advantage. Same principle here.
  #88 (permalink)
Old 01-29-2013, 02:08 PM
Thanks John, thats what I was trying to say. I am a doer not a teacher so to speak.
Dan is a wealth of knowledge and I have learned from his posts.
  #89 (permalink)
Old 02-04-2013, 08:27 PM
bentwings's Avatar
bentwings
I did a little more work with the new servo motor conversion.
After looking over the modification noted above I decided to try and change the arm ratio.
I drilled a series of holes in the side of the treadle and reinstalled the "throttle" arm link. This give a much more progressive speed increase, however it still requires a steady foot. I don't have any problem with this as I use a foot pedal with my TIG welder and I can use either foot with equal ease. I think I will add a little spring tension to give a better feel to the treadle. It will be stiffer and more like the TIG pedal. Just a personal preference. For reference my link hole is 1 3/4" from the center of the treadle pivot.
Someone mentioned sewing thru 8 layers of vinyl. So I tried this after practicing running straight stiches and some curved ones. I began folding the test piece over and running some more stiches. I also tried slow and faster rates. Eventually I got to 8 layers and even at the very slowest speed the machine will plow right thru and pull the thread tight. High speed is no contest. I couldn't fold the piece up any more so I just added a top and bottom layer and it punched right thru again. That's as thick of stack as will fit under the foot on my machine. This is with the 90mm pulley. I was going to get the 50mm pulley but I think I'll hold off and see if there is a need.
Love this servo motor!!!
  #90 (permalink)
Old 02-05-2013, 05:35 AM
Wiki Edits: 22
You can sew through 1/4" luan plywood with no problem if you want to.
Sewing Machine Bernard Sparks Interior 1 03-26-2012 11:33 PM
Beginner Sewing Machine Recommendation reddogracing Interior 14 07-09-2011 07:19 AM
used sewing machine rodrieguz Interior 1 02-12-2010 06:56 AM
Got new sewing machine in !!!!!! NEW INTERIORS Interior 1 10-10-2007 04:41 AM
Need help with that sewing machine? KennyG64 Introduce Yourself 2 08-28-2006 08:16 AM
