-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Sewing machine skipping stitches (http://www.hotrodders.com/forum/sewing-machine-skipping-stitches-225169.html)
camberoz 10-19-2012 06:36 AM
I am about to punt my machine off into a lake!
I have an older Phaff 1426(ithink) and it is skipping stitches. It seems to be completely random it will be fine then skip one then be fine the skip 2. it is driving me crazy and destroying everything i work on.
I have tore it down countless times now and can not figure what it is. needle position? string tension ? bobbin ? timing ? arrrrr
help :confused:
Hugh in NC 10-19-2012 08:35 AM
Could be most anything. I was in the apparel business for 24 years before it all went to China, etc. We could have a machine running perfectly on one fabric and change to another and skipping would start. Here are a few things to check:
1. Put in a new needle. You may have a flaw on the old one. Check again that it is threaded correctly. Change to another spool of thread (another color or size).
2. Check that the needle and hook are set and timed right. Something may have moved.
3. Use a presser foot that has as small a hole as possible for the needle to go thru. This can be a major cause for skipping. The fabric may be lifting up into the gap in the presser foot as the needle rises and causing the hook to miss the loop and cause a skip. We called this situation "flagging". We were sewing delicate fabrics. I know that you are usually sewing heavy weight interior fabrics, but a change from leather to a thin headliner fabric could easily result in skipping. Use as small a needle as possible for the fabric you are trying to sew.
4. Find an old guy that once was a mechanic in some sewn product manufacturing plant. He will have it fixed in 10 minutes.
Good luck,
Hugh
DanTwoLakes 10-19-2012 01:58 PM
That is all good advice. Another thing to check is if the thread is going through the thread guide just above the needle on the needle bar. If the thread is not going through that guide it can cause skipped stitches.
The needle size and the hole in the presser foot is probably not the problem on an industrial machine using at least size 69 thread.
Your machine is probably not a 1426, that's a long arm double needle machine. It's probably a 145 or 1245, those are all very common single needle machines.
camberoz 10-22-2012 09:52 AM
yeah its the 1245
Any site you know of for parts ?
i do need a new thread guide
DanTwoLakes 10-22-2012 11:01 AM
Here is a place: Needle Bar Thread Guide, Pfaff #91-141610-05. Pfaff parts are not cheap.
