SFI Flex Plate - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2012, 02:29 PM
SFI Flex Plate
so due to a bad starter the teeth on my current flexplate got messed up and needs to be replaced.
i was just going to buy a summit brand sfi plate and be done with it but then i started to wonder.
what do u guys think would be better with a turbo car
standard weight
heavy wieght flex plate
lightwieght flexplate
how about one of the csr aluminum flex plates
Old 03-26-2012, 09:03 PM
327NUT's Avatar
Can I assume this is a Chevy engine? if so, you can get on ebay and buy a standard Scat SFI flexplate for about $38-40....thats all you need besides a new starter.
Old 03-26-2012, 09:04 PM
bigdog7373's Avatar
Of course it's fast
Depends how much power your engine makes. I'd say a perfect combination of strenght and weight. Not too light and weak, but not too heavy and bulky.
Old 03-26-2012, 10:50 PM
yeah its a sbc, its got enough turbo to make 1100@the crank but im not going to push it that hard though, relistically ill prolly end up keeping it around 750-800 hp
car is primarily a street car with 1-2 trips a year to the track and one trip a summer to run out on the salt flats
thanks for the tip on the scat sfi flexplate thats about 20 bucks cheaper then a summit brand one
i figure any sfi flexplate should be fine for it but i was just wondering since it is a twin turbo setup if going with a heavier or lighter flexplate would have any advantages over the a normal one
a heavy one will run about 70bucks though the csr billet lightwieght aluminum one was like 250 bucks
flex plate wayneooo Transmission - Rearend 1 06-25-2010 09:12 PM
flex plate help please 49fordp/u Engine 4 05-30-2008 06:55 AM
Flex Plate superhero Engine 5 03-28-2006 10:49 AM
400 sbc flex plate wilky70 Engine 6 01-12-2006 04:35 PM
454 flex plate t/a clone Engine 1 05-18-2005 07:52 PM
