Shackle angle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2009, 06:25 PM
Old Pony's Avatar
Shackle angle?
I have a ’69 Mustang… it rides like the rear axle is welded to the frame. I took a look at the springs and the shackles are angled all the way back so they are sitting on the frame… I got a new spring and shackle kit and it’s doing the same thing (a little improvement actually, but not much). Unless I’m missing something, aren’t the shackles supposed to be in a relatively straight up and down position to allow for flex either way. Ideas?
Old 08-08-2009, 06:34 PM
ericnova72's Avatar
More for Less Racer
Sounds like the leaf spring is too long or has an incorrect arch. How's the ride height?? Good springs, and Mustang specific, or generic?? Are springs de-arched lowering springs??
Old 08-08-2009, 06:38 PM
Old Pony's Avatar
Height is good, the springs are specific for that car (from CJ's Pony Parts). I originally thought the springs were from another car, but the new ones are doing the same thing... I'm stumped... it's not like the car got shorter.
Old 08-08-2009, 07:07 PM
ericnova72's Avatar
More for Less Racer
I'd call CJ's Pony and see what they say, it's their spring.
Old 08-09-2009, 02:48 PM
Old Pony's Avatar
The spring measures correct.
Old 08-09-2009, 05:32 PM
something is really wrong with the setup. The shackle should be slightly back (almost a 45 degrees) from the frame. I would measure another mustang for arch and length.
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 39 03-29-2015 09:02 PM
Valve Stem Angles, Do they Matter? Truth or Fiction? QuenchPiston Engine 35 12-28-2006 10:11 AM
1986 or somewhere around there s10 driveshaft angle problems fumplet Transmission - Rearend 10 01-16-2006 09:20 PM
notching tubing benchracer1 General Rodding Tech 16 04-12-2005 11:02 PM
angle plug heads and s-10 mychevystang Engine 7 03-21-2005 02:37 AM
