Shadetree 327 timing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2003, 07:16 AM
Post Shadetree 327 timing?
67 327 w/petronic & 650 Holley 135K miles why do I hav to set initial timimg at about 20 degrees advanced to keep from backfiring thru carb. Tried 10 deg. Eng never been apart, could timimg chain/gears be bad?
Old 05-25-2003, 08:09 AM
BOBCRMAN@aol.com's Avatar
Post
could be bad distrib, possibly the wrong balancer or the outer ring has spun (very common problem)on your balancer.
Old 05-26-2003, 06:34 AM
Post
Thanks alot Bob, I will check out that spun outer ring, never would have given that a thought, you guys amaze me!
Old 05-26-2003, 08:02 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Post
You could also have the distributor off a tooth or two. Did you remove it when installing the Pertronix setup? As long as it's running good, I wouldn't worry much about what timing it is set to. I always set timing by ear after initial anyway!
Old 05-26-2003, 09:30 AM
Post
recheck your distributor that its sitting in the proper tooth,look at the weights on your advance to make sure there are not stuck.if your to far advance just by a little you will have detanation evan if you cant hear it you will destroy your engine slowly
