Shaft diameter on chevy water pump? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2012, 05:00 AM
staleg's Avatar
Last journal entry: Hand brake
The short water pump on my car is leaking. The pump not used, but is 10 years old. Probably that's why it leaks?
It's an Allstar Performace aluminum, high flow, short pump with 5/8 shaft diameter.
When I buy a new one, should I upgrade to the 3/4" shaft diameter? The price is the same.
Do I have to change the pulley if I buy a pump with the bigger shaft?
Old 11-02-2012, 05:30 AM
Irelands child's Avatar
I'm using a Stewart Components pump with a 3/4" bearing on my SB Ford. It too is about 10-12 years old with never any leakage (yet): Chevrolet: Stewart Components, Inc.
And there shouldn't be a problem with pulleys - though mine are Street and Performance aluminum, they were still purchased to fit a 'stock' wp
Dave W
Irelands child
Old 11-02-2012, 05:51 AM
Last journal entry: was hoping for better than this
why not just get a new seal and repair it..
Old 11-02-2012, 06:12 AM
staleg's Avatar
I will check for that, too.
The pump was bought app 10 years ago and has been sitting on the motor on my hot rod project since then.
A couple of weeks ago I did the first start start up (a big moment!) and the pump was leaking.
I'm not sure where it leaks from. It's too tight to see for sure.
If it leaks from the back cover, I guess that would be an easy fix.
Old 11-02-2012, 06:58 AM
I see no reason to use a water pump with a 3/4" pilot shaft if you have a short water pump. The standard 5/8" pilot shaft serves to locate the pulley, fan or fan clutch. A 3/4" shaft is generally used in a aftermarket long water pump.
Short shaft water pump professor229 General Rodding Tech 11 03-08-2011 12:01 PM
water pump shaft eloc431962 Engine 6 08-22-2009 02:40 PM
driveline shaft diameter redsag 78 Transmission - Rearend 4 07-23-2007 03:47 AM
Diameter of SBC short water pump inlet ken47 Engine 1 11-25-2004 08:41 AM
SBC short water pump vs long water pump and other questions Jag Daddy Engine 9 04-02-2004 09:29 AM
