Shaker Hood for 81 Trans Am - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2007, 09:35 AM
I am looking for a shaker hood for a 81 Trans Am. Anyone know of anywhere I can locate one?
Thanks
Old 01-16-2007, 12:12 PM
http://www.car-part.com/
You'll need the air cleaner assembly with the scoop too, unless you're just going to attach the scoop to the bottom of the hood.
Old 01-16-2007, 12:24 PM
elevator bolts
If you are going to attach the factory hood scoop to the hood,use Elevator bolts and use body glue to attach them to under side of hood...this works well if running a taller motor in place of the stocker...
Old 01-16-2007, 03:25 PM
I am looking for the hood itself. I have the shaker assy.
Old 01-16-2007, 05:57 PM
GMCTRUCKS's Avatar
Hood
Check www.texastransams.com they might have one.
Improving 1999 Trans Am Ram Air Hood rfowler Introduce Yourself 1 12-07-2006 04:10 PM
Removing "trim bump" ini 'glass fenders S10xGN Body - Exterior 12 01-31-2006 10:47 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 09:51 PM
welding a metal cowl hood scoop to a metal hood? project66 Body - Exterior 7 11-10-2004 11:25 AM
Door Alignment Ron M Body - Exterior 2 08-21-2004 02:43 AM
