Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Shaker scoop mounting
Old 10-12-2012, 10:56 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Real shaker scoop
What was done was to cut a piece of 1/8 aluminum to match the base of the scoop..then the center of the plate was bored to match the intake manifold and the bolt pattern so the plate was put in place and the carb was then mounted. We used a couple of long studs to fasten the scoop so it could be easily removed to access the carb and linkage..Linkage for the carb was handled with a cable up through a slot in the plate..Now that you have the general idea it is up to you to figure out the details of your particular installation..
Sam
