Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - shakin in monte
Thread: shakin in monte
Old 10-06-2012, 03:52 PM
ssmonty ssmonty is offline
Could it be too much vacuum advance? Try diconecting the vacuum canister hose from the carb and plug the carb port, and test drive it. Easy to test.
If it helps, you can get a advance limiter from Summit made by Crane pretty cheap, and tune your vacuum adv. to your combo.
