Shaking Engine PLEASE POST - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 09-25-2003, 05:37 PM
slider in wa's Avatar
Slider in Wa.
I`m out!
Slider in Wa.
  #47 (permalink)
Old 09-25-2003, 06:56 PM
ponybuster's Avatar
Engine Shakin
This is horrible..... i've tried just about everything posted....
4 cylinders are not firing.... i just dont understand
i checked all over for vacuum leaks.. the car's belts start squeaking a little when put in reverse... i just dont know what else to mention.
someone save this poor old stang
  #48 (permalink)
Old 09-25-2003, 07:16 PM
http://forums.vintage-mustang.com/fo...at=&PHPSESSID=
Try the Vintage Mustang site above and see if anyone there can assist you. Give them all of the symptoms, the previous repairs made to the car and list everything that has been suggested and tryed.
Do a search under "Mustang forums" and you'll find plenty of similar sites that are specific to your vehicle...chances are someone has had the same symptoms and will be able to direct you. I know you say that money is tight, but the aggravation in trying to locate the problem(s) will drive you nuts. It'll be a good investment if you want to determine the problem(s) accurately.
  #49 (permalink)
Old 09-25-2003, 08:49 PM
Silver_Camaro's Avatar
Superior Wheels Quality Tech
Which 4 cylinders aren't firing again?
  #50 (permalink)
Old 09-27-2003, 03:54 PM
ponybuster's Avatar
Cylinders not firing
2 4 6 7
according to the book 1 2 3 4 from front to back looking at engine
5 6 7 8 on the right counting from front to back
i hear its a carb idle circuit being blocked up
i took the airhorn off... took the float off and sprayed the hell out of the inside of the brass fitting with gumout!! it still runs pretty shaky but its much better
what do i do from here? how can i completely get rid of this
i suppose i can ride the car for now like this... but next weekend i think i'm doing a carb rebuild to get this junk out
any more suggestions on cleaning the idle circuits out would greatly be appreciated
  #51 (permalink)
Old 09-28-2003, 12:58 AM
Well if 4 plugs aren't gettin any spark at all then you need to look into your distributor... May have a cracked cap or maybe its not setting and latched down right....
  #52 (permalink)
Old 09-28-2003, 05:22 AM
roys63's Avatar
SO Has the compression been checked? Yet? And the carb checked out?,Looks like you will need to spend some Money and have the car fixed!!
  #53 (permalink)
Old 09-28-2003, 09:28 AM
ponybuster's Avatar
oih
i keep hearing its the carberator... thats all anyone will tell me
they tell me the passenger side barrel runs the exact cylinders that aren't firing..
how do you clean the carb completely out.. i've taken the airhorn off and the float and sprayed into these little jets
it hasn't helped at all
just made things worse... at first better a lot better
but now worse and sometimes better and sometimes the same
-who will save us from the sane??
  #54 (permalink)
Old 09-28-2003, 10:58 PM
From the sounds of it you got junk in your carburator.. And why you tried cleaning it it just moved it out of the passage ways for a short while.. Your best bet will probably to be to take the carbuerator off and do a complete tear down and either clean ever part and possibly buy a carburator rebuild kit and rebuild it while your at it.
  #55 (permalink)
Old 04-30-2011, 05:24 PM
BIG MUDDN's Avatar
Last journal entry: my 84 3/4 ton 4x4 longbed
okay, try this. my uncle does this when he had carb. problems. he took it apart and dropped it into a bucket full of this green degreaser stuff, i dnt remember the name. but he left it in there for a day or two and oulled it out. whiped it down and put it together and slapped it on there and it ran like new.
  #56 (permalink)
Old 04-30-2011, 06:10 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Originally Posted by ponybuster
is that all there is too it????
if you pull the wire off the distributor and the engine doesnt shake... the wire is bad
Are you not reading what's being said?
If you pull a wire and nothing changes, that wire or plug is bad.
If you pull a wire and the engine runs worse, that wire or plug is good. You made it bad by pulling the wire off.
  #57 (permalink)
Old 04-30-2011, 06:26 PM
Why don't you just get a new carb instead of messing with it yourself?
Unless you are a qualified carb rebuilder trying to fix the carb yourself is not a viable option. If you were a qualified carb rebuilder I suspect that the problem would have been fixed by now.
  #58 (permalink)
Old 04-30-2011, 06:28 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Hate to say it but you're 8 years too late.
  #59 (permalink)
Old 04-30-2011, 06:33 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Originally Posted by slider in wa
Slider in Wa.
Take me with you...
