shaking real bad - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2011, 05:22 PM
shaking real bad
67 c-10 finally got it back on the road for sitting 5 years. when speeding around 40 or so the front shakes real bad like its about to fall apart. what could that be.
Old 06-27-2011, 06:25 PM
Wiki Edits: 31
loose front end components. A arm bushings possibly. causing the front wheels to oscillate back and forth
Old 06-27-2011, 07:44 PM
sqzbox's Avatar
My pipes are my music
Are you running the same tires it's been sitting on for five years?
Old 06-27-2011, 08:45 PM
cudablack2004's Avatar
check tie rods for any play! I just replaced mine and the shake stopped
Old 06-28-2011, 08:49 AM
el pollo's Avatar
It's shady under this tree...
If it sat for five years, you probably have flat spots in your tires. Rubber holds memory after a while.
Old 07-01-2011, 11:10 AM
1971BB427's Avatar
Could be alignment, tires, brakes too tight and draggging, or any number of things. Jack the front off the ground and check for play in the front by wiggling the tires. Start wiggling top and bottom to check bearing play, then side to side to see if the tie rods, and steering pieces are worn out.
If all that is good, then spin the tires and check for runout or flat spots. Might also have them spun to check runout and balance.
Old 07-04-2011, 07:30 PM
pontiacjosh's Avatar
84 stroked ss
Last journal entry: exhaust
old and worn out bushings
Shaking V8 on start up. Alvis Alley Engine 18 01-21-2007 01:49 PM
shaking motor jo5hi3 Engine 8 08-20-2004 03:52 PM
Engine shaking... Tissue Engine 8 04-07-2004 07:41 PM
560/15's REAL pics of REAL Car! DragLinkscc Hotrodders' Lounge 7 10-21-2002 05:54 PM
help im shaking and dont know why notmrgoodwrench Suspension - Brakes - Steering 8 08-18-2002 07:40 AM
