Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - shaky brakes
Thread: shaky brakes
Old 05-05-2002, 09:59 AM
Pontiacman Pontiacman is offline
Just a thought, I'd take weight off front suspension, and grab ahold of tire and shake, wiggle, up, down, side to side. also might be a combination of things showing themself if tie rod , pitman, or idler arm bad this would also magify this problem. also wheel bearings not being seated properly. make sure your cure involves all factors described, for a total cure. just a thought, hope this helps a little
