Sharpe air filter still good? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2011, 02:33 PM
I've got a Sharpe 606A that was given to me sometime back, and I've been using while running tools. While reworking my distribution pipes, I noticed a bunch of white stuff in the inlet, when I opened it, I was surprised to find it full of white crud. Looks like aluminium oxidation, probably from the housing. Also looks like the whole top plate has been oxidizing. The chrome is flaking off pretty bad. I would assume that the previous owner didn't drain it regularly, or stored it under water. Is this thing worth using any more, or should I just replace it, and if so any recommendations?
Thanks
John
Old 01-07-2012, 06:07 AM
deadbodyman's Avatar
Wiki Edits: 11
Clean it up with a wire wheel then give it a good coat of epoxy primer. Good as new...
K&N Filter-Good or Bad speede5 Engine 19 10-31-2012 06:02 PM
good dust filter for fiberglass sunbelt57 Body - Exterior 5 08-23-2010 08:24 PM
Looking for a good fuel filter. GulfCoastGasser Engine 6 07-09-2008 11:35 AM
sharpe Spray gun is it any good Countilaw Body - Exterior 18 05-04-2006 10:50 AM
