Sharpe finex mini.. problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2005, 04:41 PM
Last journal entry: metal finish
I have this sharpe finex mini touch up gun.. i dont use it often but today when i did it would spray good then sputterer.. it would spray for about 5 seconds then sputter.. i read somehwere that there was a recall on the seals on these? could that be the problem? i playing with all my adjustments and still did it.. anyone have any ideas? thanks
Old 10-20-2005, 11:17 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
Man I tell you what bro, I have one of those things, and used it allot for small repairs etc.. worked great, and I mean great, then one day it will no longer seal at the tip...I have cleaned it every which way etc... still wont seal... IMO and it is my opinion I think Sharpe makes not soo good of guns... I know some use them and like them, but after being away from this business for many years, I am quickly remembering how "expensive" good quality tools are a must.... Maybe we can put the two of ours together and make one decent gun for a while... ..
and yes they were recalled because they kept leaking and would not seal... found this out after I had bought the dang thing.. Sorry to hear about your troubles, nothing worse than equipment that fails on ya
Matthew
Old 10-21-2005, 02:35 AM
Yea this one worked great for a few times.. now its no so great. i feel bad my brother bought it for me as a gift so id feel guilty getting a new one.. im gonna try my hardest to get it to work good again.. what part of the tip? i noticed the white washer in the aircap is a little warped.
Old 10-21-2005, 02:08 PM
BondoKing's Avatar
KING OF BONDO
Where the tip of the needle seats inside ... It leaks around there and wont stop... It is more annoying than anything... The guns still sprays ok, just hisses all the time..
Matthew
Old 10-21-2005, 03:42 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
I got one as well. Mine hissed at the get go and returned it for another. It's sprayed well so far.Who know's how long.
Sputtering is usually the nozzel not sealing to the gun properly.Or paint too thick but that's on a siphon gun usually.
Does it bubble back into the cup?
My old siphon touch up got worn at the nozzel/gun connection and would only work right if I tightened the piss out of it. That bevel seal on the nozzel got worn out and the only fix was a new one.
It's a good possiability that the white gasket just need's replacing as I believe that's what seals the nozzel. I'll look when I get home to see.
I just get the cheap one's and toss when they quit anymore.
Old 10-21-2005, 06:29 PM
more debt than brains
i have the same gun and the simular problem sputtering and the trigger does not go back to off,,, no more inexpensive guns for me
i bought a sata minjet 4 and man what a nice gun..... now i just upgraded to a digital rp also from sata, that replaces my finishline 3 guns that served me well.
jeff
Old 10-21-2005, 10:08 PM
BondoKing's Avatar
KING OF BONDO
Mine does not bubble back through the cup, but I have seen gravity fed guns do this before as well...
Matthew
Old 10-22-2005, 01:30 AM
Mine doesnt bublle back.. i hold the trigger it sprays good then stops spraying for a split second sprays good again for a few more seconds..
Old 10-22-2005, 09:04 AM
Bee4Me's Avatar
I looked mine over and this gun does not use a gasket to seal the nozzle,it's a bevel mechanical metal/metal seal as well. Overtightining is the BIG problem with these types as you distort the "seal" area with distortion or "grinding" the 2 together and eating away the proper contact area. When this happens,it's impossible to correct this as you can replace the nozzle but the gun bevel is part of the housing which is not replaceable as far as I know.
It will only bubble in the cup when it sputters,so you may not be noticing it all the time.Usually though, it does this constantly but I have had mine do this on a inconsistent basis with the paint sealing the gap for periods.
The other problem would be the O ring for the needle but you should notice it hissing and paint running down the gun.
It's possible that the cup bleed hole is clogged.This will let the gun spray good then gradually quit spraying paint then after fiddling with it do the same thing again driving you nut's as to WHY.You create a vacuum in the cup as you paint which cause less material to come thru then fiddle with it opening the cup and so forth and then it paints good for a short time then quit's again.
And, There is the obvious,simple solution. You got a piece of "something" in the gun you have not seen floating around screwing flow up. I found a piece of metal in my LPH that I never noticed until I broke it down and REALLY looked it over.
Piston/valve interference problem jameskirk1 Engine 12 12-03-2004 04:14 PM
Puzzling temperature problem on the hemi solved Centerline Engine 2 11-26-2004 03:48 PM
Temperature Sending Unit problem Centerline Engine 3 11-12-2004 05:13 PM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 05:18 PM
Ignition problem??? Centerline Engine 2 06-29-2002 05:53 AM
