shaved door handles without cutting/welding - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2005, 11:39 PM
william27103's Avatar
i want to shave my door handles but i don't have any metal cutting/welding experience, no cutter or welder, and really wouldn't want to practice on a door anyway...would it be wrong to just take the door handle off and fill the hole with filler, or would that turn out bad in the end
thanks
Old 12-07-2005, 06:12 AM
Magnus_Jager's Avatar
Tow Chainer
Last wiki edit: Rebuilding an early Hemi engine
Last journal entry: cruise pics
Wiki Edits: 2
You could take a piece of metal and panel bond it to the door. Something like fusor. That would give it substance and keep it from falling apart. Then fill to level. Quick and dirty but stronger than just fill.
Also hit it with a torch and you can undo it. (stinks like hell) Probably toxic fumes come to think of it... So I don't suggest it but it can be removed with heat. Not heat gun heat. Real heat.
Old 12-07-2005, 09:24 PM
fiberglass specialist
mangus jagers method is practical but not always beneficial..you should really take the time to weld and prep and not rush trough thing because it looks good now, but bondo has a tendency to sag over the years as a result of climate change, so i would suggest going throught the proper steps of preping the surface ans going ahead and welding a patch panel to it so you can have a strong sturdy addition to your car for years to come, without having to go back and refinishing and repaintind everyother summer!
good luck with you project, let me know how it turns out!!
Old 12-08-2005, 05:44 AM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
Bond a piece of metal or rivet in some metal and finish off with filler... I would use the metal filler evercoat has out instead of regular old filler.. then would finish with a glaze as usual... Make sure you give all the fillers a couple of days to dry out IMO before you add your primer surfacer... I say that for shrinkage reasons and you may build above the normal range.. Things do shrink after a few days, then 2k and block out with GUIDE COAT~!!!!!!
This is not the best way at all, but it will do in your situation I think...
Fast Low Buck Shaved Door Handles Ron M Body - Exterior 18 07-24-2011 12:47 AM
How'd you do your shaved door kit.... JhnBrackett Body - Exterior 20 12-11-2005 01:29 PM
confused on shaved handles 78 King Cobra Body - Exterior 3 07-26-2004 10:57 PM
shaved doors? 6speedwagon Body - Exterior 2 03-22-2004 07:29 AM
How to make home made shaved door latches? Fordy8man General Rodding Tech 0 10-17-2003 03:47 PM
